  • July 12, 2025, 01:09:52 PM
Author Topic: Suggestions for .09-.15 airplanes.  (Read 1559 times)
Offline frank mccune
« on: June 14, 2023, 10:25:24 AM »
     Hello all:
      I am wanting to use my collection of smaller engines and built airplanes.  These will be powered by Diesel engines in the .09-.15 size range and include Shark 15, Ringmaster Jr.,  Acromaster, Sterling P-40 and. Few others that were scratch built.
      I tried RM Jr. with a MVVS .09 Diesel  but it failed to have enough power to become airborne.
      Suggestions/Comments
       Frank
Re: Suggestions for .09-.15 airplanes.
« Reply #1 on: June 14, 2023, 10:47:51 AM »
     Hello all:
   I know nearly nothing about diesels aside from they are wimpy and smell bad, but if it couldn't get the airplane airborne, it probably wasn't running correctly. You could fly a Ringmaster Jr level with a PeeWee .020, even an 09 diesel should be better than that.
« Reply #2 on: June 14, 2023, 11:23:49 AM »
I’d vote for the Acromaster.  My 10 year old grandson Bryce just soloed on his with Enya .15.
Offline Jim Carter
« Reply #3 on: June 14, 2023, 02:17:21 PM »
Well, howdy!  Frank, I would have to ask "Are you scratch building or wanting kits?  Personally, I do a fair amount of scratch building and I really get great enjoyment this way.  As such, I am so thankful for OuterZone.  I found these plans interesting as I'd never heard of them so I printed off the plans and headed for my balsa bin.  I ended up with a couple of really neat little planes that have been a ball to fly.  Actually, I've built a bunch more than these but building is what keeps me out of trouble with the wife  LL~ LL~!!  Best of luck to ya!
Jim
Online Steve Berry
« Reply #4 on: June 14, 2023, 06:22:13 PM »
Well, there's always the Flying Clown qand Circus Prince, Brodak Cub (.15-size Bear), and if you really must stick with a diesel, try a .15-size Peacemaker.
Don't forget about the Jr. Flitestreak and SIG Goodyear racers (Shoestring & Buster).
Sent from my SM-N986U using Tapatalk
Offline scott v.
« Reply #5 on: June 15, 2023, 01:49:54 AM »
How about the Flying Models Bearcat and Zero
« Reply #6 on: June 15, 2023, 08:45:46 AM »
  Problem is, those are all at least as big as a Ringmaster Jr. and if the engine won't even get it off the ground, it won't fly the others, either.
Offline Steve Lotz
« Reply #7 on: June 15, 2023, 01:45:48 PM »
I'm not familiar with that engine but something has to be wrong for an .09 diesel not to fly that plane. A little Akromaster goes vey well with a MK-17 .09 diesel. Here is a video:
« Reply #8 on: June 16, 2023, 03:09:45 AM »
a .09 diseaseil in a .049 glow thing should work . Theres thousands of the . Stunters even , too .
« Reply #9 on: June 16, 2023, 03:12:12 AM »
Forra . 15 MVVS tooned and ' the Ton ' the splinters the go .  VD~ A 8x4 Taipan prop cut to 7 inch is the go . As 18.000 is where its at .
Goodyears and U K 1/2 A ( 1.5 c.c. !  :o )  might work , TOO .
Took the .012 60 foot lines one day . WHOOPS . 1 1/2 A PAW 74 Shoestring . Flew quite good . Usual screwdriver or two improvised stooge & Dug in Handle .
That an OliverTigerCob . Vrrmmm . Mine was yellow . Tissue . Quite Quick , for a 1.5 sport diesel .
https://www.stunthanger.com/smf/rat-racing-and-team-racing/12a-goodyear-or-mouse-racing/
« Last Edit: June 16, 2023, 03:32:38 AM by Air Ministry . »
« Reply #10 on: June 16, 2023, 03:38:23 AM »
Heresome Diesel Goodyear from some time back . The Pits !
The Ideas to get 3.5 a lap ( 35 Seconds for Ten , ) outerit . My astounding Miss Dara up Front . Not entirely astounding .
Apparenytly the ' Cut Off ' is best hooked up to the bell crank . When the pushrod fell of there and started flapping about
the  pilot was hitting the down line . All that was lacking was steamers . Quite aerobatic , in the trainer sense , used as that .
They need a bit of fuse reiforcing as catching they skew & the back falls off , cracks , looks marred & untidy . Super Polish Concours is the GO .
20% Nitro in say a OS 20 should see a Ton , no worries .  MVVS D7'd nibble at it , std, if WELL RUN IN . which may be your problem .Lettem Howl . underprop .
