  • August 05, 2025, 07:43:57 AM
Author Topic: BB 40 sized Stunt motors??  (Read 1924 times)
Offline Vincent Corwell
« on: February 01, 2007, 05:37:47 AM »
What 40 size Ballrace motors for F2B are available under $150??
I have an Enya40 ZXS, wondered if anyting else is available
Keep up the good work Robert, superb forum
Vincent
Offline Dick Fowler
Re: BB 40 sized Stunt motors??
« Reply #1 on: February 01, 2007, 06:45:23 AM »
Vincent... how do you like it? Or is this the reason you are looking for other engines?
Dick Fowler AMA 144077
Kent, OH
« Reply #2 on: February 01, 2007, 08:05:28 AM »
Various Fox 40's, Magnum 36XLS, Thunder Tiger 36, and half a dozen other Asian clones, OS 37H heli engine, and maybe a few more.  None of them were designed for CL stunt, so you either have to adapt to their high rpm habits or do some significant work on them.
Offline Leo Mehl
« Reply #3 on: February 01, 2007, 11:35:31 AM »
A good old Siper Tigre 40 would do the trick. They can be found.
« Reply #4 on: February 01, 2007, 11:58:41 AM »
The HP 40 is one of the lightest if not the lightest of the twin ball bearing 40's.  (9.4 oz per catalog listing)  They have been set up to run well for CL Stunt.  They are available from MECOA at
http://www.mecoa.com/hp/ffgc.htm
Offline James Lee
« Reply #5 on: February 01, 2007, 02:58:59 PM »
The OS 46 SF came in a -S version for CL and there was a 40 size of that motor, but I don't know if it came in the CL version.  The 46 is stout but not light and the 40 would be heavier....  FWIW
Jim
Offline Crist Rigotti
« Reply #6 on: February 01, 2007, 03:35:13 PM »
Len Neumann has engines that size.  Here's a link to his website:
http://clstunt.com/engines.htm
Offline L0U CRANE
« Reply #7 on: February 01, 2007, 06:29:55 PM »
Vincent,
The OS 46LA-S is available, reasonable in price, and just about ready to go stock out of the box.
A bit larger than 0.40 cu in, but easier to use than the 40LA according to many comments.
A chip muffler, low pitch prop, 10/10/10 fuel, and go...
\BEST\LOU
« Reply #8 on: February 02, 2007, 01:13:45 AM »
Thanks for the replies, friends
To Dick Fowler:
The Enya is everything I need
It is the only BB motor I have, just curious about what
else is out there, and now I know
Vincent
