General control line discussion => Open Forum => Topic started by: Gary Alspaugh on April 02, 2015, 01:25:35 PM
Title: Stunt Fuel
Post by: Gary Alspaugh on April 02, 2015, 01:25:35 PM
Do I use 5% or 10% nitro with a LA 46 in my stunter?
Title: Re: Stunt Fuel
Post by: Dennis Moritz on April 02, 2015, 02:17:31 PM
Depends. 10 will give a fatter needle a bit more power and less duration. 5 will do the opposite. Usually.
Post by: Randy Cuberly on April 02, 2015, 02:22:51 PM
Where do you live, as in what's the altitude, general temperature, and what airplane are you using the engine in.
There is really no universal stunt fuel if you're serious.  If you're not serious just use the cheapest stuff you can find with at least 20% oil.
If you are serious just answer the above questions and I'll tell you.  Very likely a lot of others will also and you'll still be confused!
Unfortunately it's one of those questions!! y1 y1 LL~ LL~
Post by: peabody on April 02, 2015, 03:33:37 PM
I'm a believer in 10%.......easier to needle....
Have fun!
Post by: Brent Williams on April 02, 2015, 05:23:34 PM
With regards to the question of needle sensitivity, will lower nitro content fuel be less sensitive on the needle settings or more sensitive?
Post by: RknRusty on April 02, 2015, 05:26:42 PM
Less nitro makes the needle more sensitive.
Rusty
Post by: Randy Cuberly on April 02, 2015, 08:25:06 PM
Actually more nitro requires a richer needle setting and typically it is less sensitive but not always.  That depends on compression and venturi size, etc, etc, etc.  Not to mention the glow plug and prop load!
Post by: Steve Helmick on April 02, 2015, 08:53:52 PM
We usually use 10% simply because it's what the R/C guys want. Keeps the glowplug hotter for their prolonged idle and they seem to think that a dead-stick landing is dangerous, for some reason I've never understood. I did fly R/C (and CL and FF) until my Sr. year in HS.   y1 Steve
Post by: Matt Colan on April 02, 2015, 08:56:24 PM
I use 10% only in the LA 46's I've run. They're just too wimpy on 5% when you get above a 60 degree temperature, at least that's what I've found.
Post by: Randy Cuberly on April 02, 2015, 09:06:16 PM
Come to Tucson when it's 100 degrees at 2400 ft elevation and you'll find they can be wimpy on anything less than about 25% nitro!
15% works OK here in the winter time.
