Hi
When I first saw the Strega ARF about 10 months ago I just had to have one, however, the price I was quoted by our local Brodak dealer at the time was around $540 Australian dollars. I thought this could not be right so I tried SS Hobbies who were a lot cheaper but could not ship me one due to airmail size limitations imposed by Australia Post. So I went straight to Mr Brodak and asked how can I get one? I told him I wanted a good one. I don't know how he did it, but he got one to me for around $230 australian dollars. It arrived in the mail so I am not sure how he got around the Airmail size limit. So my first challenge was over.
While waiting for it to arrive I read all about the Strega and asked lots of questions here and on SSW. I learned that the LE needed rounding off abit more and that the flaps were possibly flimsy and the engine mounting could be suspect.
When the kit arrived much to my excitement the wing was not warped, the flaps were very rigid, the covering was tight and it was all in tip top shape. I decided to put in a new Saito 62 which I had just purchased for the Strega. I put it together over 5 weeknights, including making my own 5oz clunk tank, rounding off the LE and adding my own numbers and decals. The balance was just ever so slightly forward of where it should be so I added a little bit of lead to the tail wheel. Less than a 1/4 oz.
First flights on 70ft lines were very impressive but the thing was a bit fast and felt like it would pull my arm off with a 13x6 wood prop so I backed the throttle off from 3/4 to about 2/3. Much better but i had a sore shoulder for days. Around this time I posted a little video snippet on Youtube and got hammered by lots of SSW wankers because they didnt think my figure 8 was very good. Anyway this video has now been watched about 4000 times on the tube so you be the judge. Sure I am not an expert flyer but I can usually pull a score in the low 800s.
I continued to fly and trim the model and I got it to the point where I was happy to try it out in competition. A couple of weeks ago I went to the Hunter Valley Championships here in New South Wales and suddenly discovered I was using less and less fuel to fly for 7mins. I was taking out about 1.5 oz out of the 5oz tank and still over running. So I went to 2oz and found this was too much because it cut out in the 3rd leaf of the clover, flew straight at me and into the deck at 90 deg.
The wings broke off and the engine bolts were bent as the motor was forced back about 1/8". So I took it home and in the next 5 week nights put it back together and it's now looking like brand new again and flying just as good. While reinstalling the wing I checked everything internally and found it all to be good. I'm looking forward to flying it again this weekend.
I find that the Saito 62 has ample power and the overall dry weight of the plane is 74oz.
The engine is running at around 8400 rpm with a 13x6 TF power point prop. The balance point is spot on as per the plans and it turns very well. If I forget to remove the C cell Glow starter which I have done once or twice the extra nose weight makes it noticably harder to turn but it can still do loops wingovers and inverted flight but tight turns are impossible. So I would suggest if you haven't got your CG right then get it right and this plane will be a lot happier.
That's my story and here's a pic
