  • July 17, 2025, 06:08:39 PM
Author Topic: Stooges- They are an instrument of the devil!  (Read 15739 times)
Offline John Castle
  • The Bent Pin
« on: May 04, 2011, 08:23:23 PM »
And it was such a beautiful day too.
John Castle
McMinnville, Oregon
AMA# 589650
Re: Stooges- They are an instrument of the devil!
« Reply #1 on: May 04, 2011, 08:26:46 PM »
   Flying off a stooge is about the most dangerous thing that we do regularly. I pretty much won't use one any more - I had a few near-misses but there are so many accidents that others have that I don't consider it worth the risk.
Offline Will Moore
« Reply #2 on: May 04, 2011, 08:28:42 PM »
So John, what happened ?
Things take longer to happen than you think they will,
Then they happen much faster than you thought they could.
 AMA # 209
Online Howard Rush
« Reply #3 on: May 04, 2011, 08:29:57 PM »
I pretty much won't use one any more...
That's because you have friends.
« Reply #4 on: May 04, 2011, 08:32:20 PM »
   Inexplicably, yes.
Offline John Castle
  • The Bent Pin
« Reply #5 on: May 04, 2011, 08:51:46 PM »
Even though I try to be very methodical and careful when flying I do find myself focusing on the upcoming flight to the point of tunnel vision. Today I managed to take off and drop the stooge line over the top of the control lines. The stooge line is one of those wind up plastic line holders. At the point that it took hold of the control lines it proceeded to in an instant yank the handle out of my hand, snap the leather (notes taken) wrist strap and head off happily toward the neighbors house and electric lines. ~^ Luckily the handle caught the top of a tree and proceeded to slam the plane in a forceful and loud manner nose first into the asphalt driveway. Close call in lots of different ways and I am happy to get away with only a splintered plane, shredded lines, a lost handle (still in the top of the tree) and a motor that will most likely run again after a little work. Unfortunately I have to fly with a stooge or not fly at all so I hope I can take home a few lessons from this.
Anyway, life goes on,
John Castle
McMinnville, Oregon
AMA# 589650
« Reply #6 on: May 04, 2011, 09:02:55 PM »
I have been using a stooge for 16 years with only one incident. I got my feet wrapped up in the stooge line and had to do 5 inverted laps to get untangled. I learned to drop the stooge line far to the right of my lines, and where I stand.
« Reply #7 on: May 04, 2011, 09:07:30 PM »
I wish you had video. S?P
Online Paul Taylor
« Reply #8 on: May 04, 2011, 09:17:31 PM »
If I have a choice I would rather not use one. But not all of us have a big pool of friends that fly control line that live close by. And it is hard to schedule time when you do have people close by.
So I keep a stooge in my truck when I need to fly and can not find a flying buddy.
I think they can be safe as long as you have a routine and stick to it. I try and do it the same way each time.
I always double check to make sure the plane is connected to the stooge.
I always put a screw driver in the ground and put the thong on it.
My stooge line is a colored chalk line and I always run it out a few feet shot of my flying lines. This keeps me from having to pull the line past my body.
I always toss the line away from me then walk a good 10 ft or more away from the line.
You make it as safe as you can.
Offline Garf
    • Hangar Flying
« Reply #9 on: May 04, 2011, 09:25:59 PM »
I only had one incident, where the release line tangled with the control lines. Luckily they came loose. After that, I maintained seperation to prevent that.
Offline W.D. Roland
« Reply #10 on: May 04, 2011, 09:44:27 PM »
Stooges, one of my tools.
couldn't fly with out one! Well could go fly R/C with the 'normal persons'.
My problem is the unintended and repeated main gear arrester carrier  landings .
Stooges do work better for left handed persons.
Makes my inverted head go in the dirt.
 LL~ LL~ LL~ LL~ LL~ LL~ LL~ n~ n~
David Roland
51336
« Reply #11 on: May 04, 2011, 11:57:43 PM »
So how do you practice alone if you dont use a stooge Brett ?
Ive only had 1 incident where I was walking to the handle holding the lines, and realised the lines were being pulled closer to me.. my instinct kicked in, I grabbed the lines and turned around to see the plane taxing off ----> that direction. I managed to grab the handle the right way up, and continue flying without any damage.
Now Im MUCH more thorugh with my precheck routine. I fly each flight as if someone told me " Today you will make a mistake and crash your model " I preflight routine check everytime 100%
Offline Rafael Gonzalez
« Reply #12 on: May 05, 2011, 01:57:33 AM »
I've used one almost 90% of the time when I fly. Most of the guys around here, fly on the days during the week when the weather is good. I can only fly on the weekends; not retired still working. I have a method. Use a fluorescent cotton line and set it about 10-15 feet from your lines. As you WALK to the handle, stay aware of where your stooge line is. Pick up the handle, tie your strap, check the up/down and walk in an arc with tension on your lines to your release cord. It doesn't matter where you end up on your stooge line,  just grab the slack and pull.
Has worked for me. H^^
Offline Chucky
« Reply #13 on: May 05, 2011, 03:03:03 AM »
Sorry to read of your mishap, John.  When I first got back into C/L, I was the only one doing so at an R/C club, so without my trusty stooge, I couldn't have flown.  In the hundreds of times that I've launched aircraft with it, I've had one mishap, which left me with a wrecked airplane and a deep and abiding respect for the pilot responsibilities associated with safe usage.  This is not rocket science, but it does most certainly require one's full and undivided attention.  I've been careful and fortunate enough to have not had similar problems since my last, but am never totally comfortable while walking to circle center during a stooge launch.  If the release line is a likely source of trouble, have you considered an R/C stooge?  Have seen a couple that didn't look to hard to build from a few basic R/C components.
Chuck Winget
Dwayne
« Reply #14 on: May 05, 2011, 05:27:58 AM »
Wow I'm sorry to hear this John sounds scary to say the least I'm glad no one was hurt.. y1 I've only had my feet get tangled a couple of times I burned the tank out doing wing overs and lazy 8's no harm done, also I use dollar store twine if it ever got wrapped on my lines its far weaker and shouldn't cause the situation you experienced but I'll be a little more carefull from here on out.
« Reply #15 on: May 05, 2011, 07:20:29 AM »
I'm pretty much left handed since I lost half the bicep in my right arm. Tossing the stooge line isn't an exact science when you have trouble letting go of an item, so I use my left. I like the stanley chalk line for the stooge line, it's easy to see, I toss it under my lines and slightly away from me. I have no doubt though, that I could throw it underhanded or sidearm after takeoff, and get it clear outta the circle.  H^^
Offline Russell Shaffer
« Reply #16 on: May 05, 2011, 08:24:09 AM »
Be careful tossing the stooge reel.  I once tossed it over the lines and had some excitement.  Now I just drop it and step back from the soccer cone I use to mark the handle and circle center (on grass).  I always stake the safety thong and walk on the back side of the lines on my way to the handle.  The theory is that if the plane gets loose the lines will move away from me and the thong will pull full down as soon as there is tension. Hopefully the airplane will nose over before it gets airborne and all I will have is a broken prop.
Russell Shaffer
Klamath Falls, Oregon
Offline Terrence Durrill
« Reply #17 on: May 05, 2011, 08:26:23 AM »
I have been using stooges, mostly of my own design, since 1955.  It pays to have flying buddies, but that is not always the case.  I started with stooges made of coat hanger wire to launch 1'2A stunt and sport planes in the mid 1950's and moved on to larger planes in suceeding years.  I did vow never fly anything larger than a 35 engine off of stooges, for several reasons.  One of these reasons came out of the one incident I had with a stooge and a Green Box Nobler/Fox .35. On takeoff, I got the stooge line tangled up around my feet, but I got out of that o.k.  If that had been a Sig Magnum with a ST .60, I would have been in trouble.  So, I believe that the size of the plane and engine are a factor when using a stooge. If you are not a serious competition type, just a weekend sportflier like me, I recommend you stay with smaller planes and engines when launching with a stooge........Just my thoughts on stooges.........TDurrill  n1    y1    H^^
Offline Louis Rankin
« Reply #18 on: May 05, 2011, 08:48:22 AM »
While pull testing lines and handle straps in the Classic event at the NATS a couple of years ago, I encountered three strap failures.  Yep, all three were leather straps.  I would never use leather and do not recommend its use for anyone!!!
Louis Rankin
Somerville Tennessee
AMA 10859
« Reply #19 on: May 05, 2011, 09:50:08 AM »
I have used a stooge since I first started flying 1/2A's in the back yard.   Now who says normal people fly RC?   My second plane was a built up high wing trainer.   Had already had several flights on it when I met the hobby shop owner at his field to fly.  Had just taken the plane and radio off the charger.  He has the habit of checking batteries with his checker.   All was go.   Took off and was doing passes around his field to get oriented.  Halfway into the tank the plane goes bananas.  Into deep grass inverted so very little damage.   Found out the on board receiver battery had a cell go open.  And these RC people think they have complete control of their planes while flying.  Nothing like someone turning on while you are flying.  Had it happen too many times to talk about.
But, flying by ones self does mean you have to be more alert and cautious.   H^^
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #20 on: May 05, 2011, 10:12:15 AM »
I fear no stooge.
L.
"I keep tryin' ta think.. but nothin' happens!" - Curly Howard
Offline jim gilmore
« Reply #21 on: May 05, 2011, 10:29:43 AM »
Not knocking anyone here....but I would think safe method would eliminate the problem even if remembering that the c/l have to be 100% clear and the stooge line must be in a position to do the same.
Solution is to
1. route c/l and stooge line..
2. route stooge handle behind c/handle..
3. always pick up c/handle first and using the left hand pick up stooge handle.
This should leave lines on top..stooge line on bottom..always back away once you release the plane...
Offline Russ Danneman
« Reply #22 on: May 05, 2011, 11:03:17 AM »
great quote larry!  one of my co-workers likes to use that one the bosses here! it just zero's them out.   rd
FLY LOW FLY FAST  RISKY BUSINESS
Offline sleepy gomez
« Reply #23 on: May 05, 2011, 11:34:02 AM »
The stories of stooge problems above relate to the stooge line.  The stooge I have used for many years has no line nor does it have any moving parts to fail.  Operation is simple- just pull the plane to you!  Refer to this as a LINELESS STOOGE.
« Reply #24 on: May 05, 2011, 03:22:47 PM »
I fear no stooge.
L.
I was shocked when I saw this thread. As someone who grew up with the Stooges, I cannot believe these horrible, disparaging remarks that are being made.
Were the Stooges involved in devilish activites-YES. Does that make them instruments of the devil-absolutely not. I sincerely hope that we will come to our senses on the thread, and acknowledge the good that they have contributed to our society, (wicked laughs).
By the way, they are currently making a remake of the 3 Stooges, and I am deeply concerned that they will see this thread.
« Reply #25 on: May 05, 2011, 03:32:52 PM »
  What keeps it from vibrating off the the left and releasing itself early?
Online RC Storick
« Reply #26 on: May 05, 2011, 04:33:57 PM »
The thing that worries me the most about flying off a stooge is not getting caught up in the wire but accidentally cutting my self with the prop and going into shock and passing out.
A carbon prop could take your finger off easy.
Offline jim ivey
« Reply #27 on: May 05, 2011, 05:30:36 PM »
Thats why ya need 3  woo woo owoo nyuk yuk yuk hey moe!  Hey Moe
« Reply #28 on: May 05, 2011, 05:38:22 PM »
And what keeps it from hanging up and getting the nose pointed into the circle?
« Reply #29 on: May 05, 2011, 06:58:30 PM »
 1.  The plane can vibrate around but if the engine is running and the prop is spinning it won't back up which it has to do to release.
 2.  There is nothing for it to hang up on.  It slides off the "hook" which can actually be straight rather than curved.
3.  Note the angles of the plane, the hook, and the control lines as they relate to each other.
Tradition is the enemy of creative thinking.
John Leidle
« Reply #30 on: May 05, 2011, 07:45:36 PM »
   Louis Rankin,
  I think it was 2007 you pulled my safety thong at the Nats Classic event and it broke but mine was cloth shoelace I think ,,point here is you took the time to check safety thongs and some broke, I didnt think mine would fail but it did, Thanks for being there,
  Also on the thread's subject I was flying a week ago & went over to watch a guy fly his new plane, He had a stooge setup .I have seen his stuff before but only this tme I was thinking in my head what a Mickey Mouse piece a S#h!t* stooge   thing he has, and as he got his PA .61 started  it prematurely released,,, he grabbed the nose of the fuse & saved any injury...  these things can give way .Mine could fail as well. Good topic & thanks for the reminder.
  john
Offline Michael Massey
« Reply #31 on: May 05, 2011, 10:38:38 PM »
I have been using the stooge since my "reentry" to flying about 2 and a half years ago.  My only real concern was having the plane come off the stooge before I could get to the handle.  To take care of that concern I have a larger weight attached to the thong (which is on the "down" side of the handle).  I figure if a dandelion can grab the down line on take off and cause the plane to nose over, a larger weight should be more than adequate.  After all, we are not trying to hold the airplane if the stooge fails or the plane gets loose, but only want it to nose over and stop.
Eagle Point, Oregon
AMA 914713
Offline Chucky
« Reply #32 on: May 06, 2011, 02:25:30 AM »
Sleepy, I've seen several variations of your lineless stooge.  However, others used a slotted piece of sheet metal mounted a little above the base plate to capture the tail wheel.  How does yours attach to the aircraft?
Chuck Winget
« Reply #33 on: May 06, 2011, 10:37:06 AM »
Hi Chucky, Using a wire above the tailwheel could allow the tailwheel to jump the wire.  Not having seen the sheetmetal slot type I wonder if there might not be too much friction for and easy release.  I use a loop as shown in the drawing.  This loop works on pin type release mechanisms.  The loop is attached to the tailwheel wire.
Offline W.D. Roland
« Reply #34 on: May 06, 2011, 11:16:21 AM »
   Now who says normal people fly RC?    H^^
Could of been me. Normal in today's world and I agree that that is not normal! LL~
Picture of my stooge. 4 huge nails anchor to ground(10-12inch long) at start end of 1/4 paved circle.
Airplane on pavement. Will make better,compact version one of these days. Chalk line release.
Problem:
Fox .35 mounted profile will try to make a tail in circle around stooge before you can run to handle.
All but a few of my Sport and Stunt planes do this to some extent. some do it after picking up handle when weight of lines add to situation.
Solution:
2x1x12 inch steel bar layed on inside of main wheel just touching wheel and LE of bar about even with wheel.
Bar is place parallel to fuselage.
David
David Roland
51336
« Reply #35 on: May 06, 2011, 11:25:20 AM »
would like to see video of sleepy's in action if possible.   #^  thanks rd
« Reply #36 on: May 06, 2011, 11:42:27 AM »
Sorry, RD.  I don't have video equip.
« Reply #37 on: May 06, 2011, 12:09:41 PM »
  Well it seems like it could pretty easily shake itself off to the left and then release the hook. I have seen too many issues with premature releases that I think this one is pretty scary. You need something with a positive retention.
Offline W.D. Roland
« Reply #38 on: May 06, 2011, 12:44:07 PM »
If on pavement they will most likely walk left. Grass, not to bad.
Profiles are biggest offender.
David Roland
51336
Online Les McDonald
  • " The Jelly Man"
« Reply #39 on: May 06, 2011, 01:25:00 PM »
I promised myself not to respond to this thread but I can't take it anymore.
How can anyone practice flying stunt without a stooge?
My exwife, Nancy, was the most tolerant person on the face of the earth but no way could she possibly be available every time I wanted to fly.
You guys either don't fly much or have a circle of friends that show up at the field at 6AM or after work, everyday. Maybe you can have someone meet you in twenty minutes so you can try out a prop you just whipped up. That certainly was not an option for me.
I was amazed when I read here that Brett doesn't use a stooge. He's one of the top guys, how does he do it?
It is also been my observation that if someones launching for you they have a plane with them also so the circle would need to be shared. That cuts "your" flying time in half. That's fine when you're in coaching mode but when you're trimming you need to "git ur dun".
I used a "Bob Baron Stooge" for many, many years and thousands of launches. Never an incident or concern, ever. My trusty stooge never let the tail spring up or caused the plane to weave because it was the same launch each and every time. I never tripped over or struggled with the stooge line either. I will admit I always flew over pavement and my stooge was screwed into lead anchors with long drywall screws. I had these "stooge mounting points" at several circles that I used in North Miami. Some may even still be there.
I see people my age out there climbing mountains and zip lining and here I am feeling good about myself because I got my leg through my underwear without losing my balance
Offline Chucky
« Reply #40 on: May 06, 2011, 02:16:47 PM »
Thanks Sleepy.  Same setup I currently use on my planes.  Will give your stooge a try and get rid of the release line.
Chuck Winget
« Reply #41 on: May 06, 2011, 02:34:18 PM »
  Well, first potential erroneous assumption is that I am any good at this!
  I fly on average about 75 flights a year. In recent years it has been quite a bit less. Between the 05  NATs (where I wrecked my airplane the night before qualifying started) and the 06 NATs I think I flew a total of about 30 flights of all kinds, and about 20 of those were official.
  I used to fly a lot more (including thousands of flights with a stooge), but it isn't necessary when the engine performance is so good, and the repeatability is so good, that you don't have to spend a lot of time learning to compensate for things or learning the airplane characteristics. I also fancy myself good at trimming and supposing that was true, it makes it even easier. All I have to do is remember to keep my head straight up and down, and do the maneuvers in front of me.
   Having said all that, while I can almost always be competitive (flyoff at the 07 NATs aside) I do tend to get ground down by Orestes, David, and Paul over time. I will be going along great, then make a big mistake, and then lose by a point or two.  Those guys all fly A LOT. Whenever I try to do that, I get to the point of making a bunch of "glitch"-type mistakes and never get past it, like a golfer with the "yips". That's essentially what happened at the 07 NATs, trying to defend and trying not to fall into the trap of resting on my laurels, and while I did pretty good most of the week, on flyoff day I was a disaster. And of course once you start struggling, trying harder makes it worse. The "occasional big mistake" problem would probably get better with a lot more practice but I haven't been able to fly enough to get past the dip in the learning curve.
   My best performances (2004 NATs, 2006 NATs, 07 Golden State, and 09 TT) were all after pretty long periods of little or no practice. 2004, particularly, since I was primarily a toolbox carrier the previous two weeks (a job clearly within my capabilities!). And of course 2006 since I didn't get the new airplane finished until the weekend before the NATs. It had 22 flights total by the end of the flyoff.
« Last Edit: May 06, 2011, 07:49:41 PM by Brett Buck »
  • Red Hot Lover
    • Stephanie Miller
« Reply #42 on: May 06, 2011, 03:51:29 PM »
For years I watched Bill Melton fly his killer .60 sized carrier ships off our grass field, using a simple stooge consisting of three 6" (or so) lengths of wire, with a closed loop bent on one end, and the other end sharpened. Two were pushed into the grass with the loops sticking up. The third had a long string tied to it and passed through both loops, and also pressed into the grass. The other end of the string had an inelegant scrap of pine tied to it.
In all that time, I never saw Bill ever have any stooge incident, and these carrier ships were howling! (I saw Bill get wrapped up by a throttle line which broke at the engine, and running for a couple of minutes at full throttle before Bill managed to fly the ship into a small tree.. But that's another story).
So, I emulated Bill, copied his setup, and used it for a CL Stunt stooge. It worked OK until one day as I pulled the stooge line, the combination of its line stretch and the force needed to dislodge the "pin" through the loops caused it and its line to spring and launch itself into my lines. Fortunately after a couple of laps, I managed to dislodge the stooge line and pin from my lines.
After that happened I mentioned it to Bill and asked if he ever had that problem. He said it never happened, and when I asked why, he said he "didn't stick the pin too deep in the grass".. Sorta a doctor reply to "when I move my arm it hurts", as "then don't move your your arm".. Classic Bill Melton. (I still miss the guy..)
Anyway, after reading an article somewhere, I went to a "captive" stooge line setup, with the release mechanism made from a door hinge, ballpoint spring, washers, nail, etc. for the release mechanism. (Similar to what you see above). Rather than describe it in great detail, here are a couple of photos. It's about 24 years old I think.
I'll also mention that the line reel is stored with the stooge, which can hold the reel while you pay out your line through the slot on its edge as you are setting up. And the three large nails are of course to secure it to the ground. The bottom part has cutouts for easy grip during removal from the ground. If you fly off pavement, of course you add a heavy board or metal plate, and use three bolts to secure the stooge holder/launcher instead of nails.
I wish I could remember the specific article I where got the design, somewhere in FM around 1987 perhaps.. Anyone remember it?
Of course, if you're no longer doing things "the Cowboy Way", you can simply cough up the bucks to get a commercial one, available in various levels of sophistication and beauty.
L.
"If you want others to have a good opinion of you, say nothing." -Blaise Pascal
« Last Edit: May 06, 2011, 04:23:37 PM by Larry Cunningham »
Offline W.D. Roland
« Reply #43 on: May 06, 2011, 07:40:54 PM »
Les
That looks same as my stooge other than Fabricated VS Milled.
Like you I have never had a misfire from the unit.
Watch out for the drywall screws, Hard and brittle. Shear.
Throw away when you remove them and use new for each session.
These are the Black or Galvanized Philips head version?
David
David Roland
51336
Online Les McDonald
  • " The Jelly Man"
« Reply #44 on: May 06, 2011, 09:14:39 PM »
David, the screws don't matter any more since I was describing my experience from at least 27 years ago!
Offline W.D. Roland
« Reply #45 on: May 06, 2011, 09:47:30 PM »
Woah! We gotta get you flying again!! LL~
 H^^
David
David Roland
51336
« Reply #46 on: May 07, 2011, 10:48:27 AM »
     The important thing, compared to the OP, is that this one  has *positive retention*. Mine is similar, with a spring-loaded pin that captures the hook. The airplane is completely captured and something has to break before it is released prematurely. If you feel you must fly with a stooge (and I know that a lot of people do, and are going to continue doing it), I think you *must* at least have this level of safety. Sleepy's stooge, with all due respect, is *absurdly dangerous*.
    Other tips:
     Run you lines *before* you start the engine. Once the engine starts, stay clear of the lines in all circumstances, do not touch them or grab for them if the airplane releases early. The worst accident I know of involved someone running out the lines when the airplane released early, and it cut his fingers to ribbons, basically "degloving" two of his fingers. That's the accident that stopped me from doing it any more. It's much better to let the airplane take off and crash than it is to amputate you fingers or strip all the squishy parts from the bones.
     Before you start the engine, or even choke it, pull-test the airplane to make sure the stooge is really hooked up, and check visually that the release pin is fully seated. I painted part of my pin fluorescent yellow where it is normally covered when the pin is fully seated. If you can see the yellow the pin is not seated all the way.
    Also check the tailwheel strut (or whatever else you attach the stooge with) attachment before and after every flying session. I think they have to be heavily built up for long-term stooge use. That's another reason I don't like it, it means I need to add an extra 3/4 ounce to the tailwheel mount. But whatever you use, its right on the bottom where all the oil ends up and it tends to get very oil-soaked.
    Set the lines out straight, and then the stooge line about 3 feet behind them. Be very careful to check the clips so they are not flipped around and are straight. When the engine starts, walk out to the airplane *behind* the lines and stooge line. That way, if the airplane releases, you will not be in the way and get wrapped up in them, and get cable-sawed. Remember that you are by yourself, pretty much by definition, so if you get any more than a minor injury you are immediately in big trouble and a significant cut could result in you bleeding out before you can get help.
    Don't choke the engine, apply the battery, idly flip the engine, without positive control over the airplane, meaning hold on tight with your arm clear of the prop. Modern engines start without the battery *all the time*, very easily, sometimes even when rocking back against compression from the weight of the piston. If the stooge isn't completely captured, and it starts, and you have no control over the airplane, it will chop you to ribbons. A piped 61 with a carbon prop isn't going to stop when it hits your knee or cuts your femoral artery or other important items in that general area. Note that it is also very difficult to control the prop when you attach the battery, and you pretty much have to reach through the prop disc to attach it, if you are holding the airplane by yourself. They also start sometimes right when you attach the battery, there goes all the veins and probably arteries in your right arm. You bleed out and die.
    When you get to the handle, attach the thong, and then pick up the stooge line handle. Pull it to release the plane, and then throw it, hard, out behind the lines (off to the right if you are flying CCW). Its easy to get you feet wrapped up in it if it's anywhere near you. We have *all* done that, whether we admit it or not. Worst-case is that you fall and crash, so its not life-threatening like most stooge problems, but you will lose the airplane.
     If you pull, and the airplane doesn't take off, you are stuck, do not put the handle down and go check on it. It may shake itself loose and then off it goes. Just let it run out the tank. I use the Kevlar lines for the stooge release, this has little "give" so it's more likely to ensure you pull it all the way. Fishing line, string, etc, stretches and you are never quite sure that you pulled it hard enough.
    Try to land so that the roll of the airplane puts it right back near the stooge. On pavement this is pretty easy, and you can get it within a few feet with a little practice. The reason is that you are going to have to drag the lines when you put the airplane back to the stooge. Dragging the lines, they will get caught on various things on the field. When it happens, don't just yank on them, go clear the snag. Check the lines carefully after each flight for line damage caused by dragging them.
    Always have a cell phone with you, in your pocket, with speed dial to 911. Don't leave it in the tool box, because you might not be able to get to the tool box. That way you can call for help if you get hurt. The single biggest danger is getting cut and bleeding out before you can get help. Its potentially fatal, it's no joke.
    To me, after seeing numerous variations on the above (none fatal, in many cases due only to dumb luck), I pretty much stopped doing it. To me, it's not worth it to get in a few more flights, and with current airplanes and engines the injuries are potentially far more severe, and 5 extra flights not that critical. I think this makes the risk/reward far different from the good old days, where you really needed a lot of flights, and we were running Foxes or ST46s with wood props. I did on the order of 5000 flights with stooges, back in the good old days, and I am still alive, but to me anymore it is just too risky.
« Last Edit: May 07, 2011, 12:27:20 PM by Brett Buck »
Offline Frank Imbriaco
« Reply #47 on: May 07, 2011, 07:27:05 PM »
 Someday, I want to work something out using a foot pedal to release the cord. A drummer's pedal might do the trick.
« Reply #48 on: May 08, 2011, 09:32:00 PM »
Sorry Brett, MY STOOGE IS NOT ABSURDLY DANGEROUS. I am surprised that you from your high and mighty position would say such a thing.  I suppose you must have had extensive hands on experience, not armchair supposing, with this type stooge.  What is dangerous is traditional thinking without solving problems, a category that many "old timers" fall into.    If your plane vibrates so badly that it would walk off the platform then balance the prop and check the piston weight.  Of course it would be too easy to tilt the platform slightly to the right.
« Reply #49 on: May 08, 2011, 09:47:42 PM »
   On the other hand, "old timers" have seen a lot more stuff than you have.
     Sorry, Sleepy, I have been doing this for a heck of a long time and there are far too many accidents with stooges, even those with reliable positive retentions.  I think yours is far too dangerous, and it certainly offers no advantage over a regular type. We are talking about potentially deadly accidents and no flight is worth killing yourself for,
