  • July 15, 2025, 08:43:37 AM
Author Topic: Stooge With a Footpedal ?  (Read 1741 times)
Offline Frank Imbriaco
« on: May 12, 2010, 12:17:46 PM »
I've seen on this forum  many varied ways of making a  stooge to hold Ukie  models. I think a foot actuated system is worth considering, but before I try to reinvent the wheel, has anyone seen one or better yet, is anyone using one now ?
I have the Brodak unit which is acceptable, but  it would be far better (IMO) with a simple mechanical foot pedal device and 60' of mason's flourescent cord  for   retracting  the pin  rather than a handle to yank.I've checked McMasterCarr, Harbor Freight, and  some others(but not Toyota)-even considered  a drummer's pedal.
Frank
Re: Stooge With a Footpedal ?
« Reply #1 on: May 12, 2010, 01:20:12 PM »
One downside is that if you trip over the line on the way out, the model will release.  And the release line would have to be in tension to begin with to make the foot pedal work, so the chance of malfunction is further increased.
I just use a home made "Brodak-type" unit with a strong spring.  I guess I could still trip on it and release the plane, but with the end hanging loose, there's less chance of it.  The spool of nylon cord from Home Depot at $5 gets the job done, with a few feet to spare for safety thongs.
In any case, looping the safety thong over a peg in the center is a good fail safe.
« Last Edit: May 12, 2010, 03:04:08 PM by Paul Smith »
Offline Russell Shaffer
« Reply #2 on: May 12, 2010, 01:29:25 PM »
You also want the stooge line flat on the ground while flying.  Otherwise it makes a good arresting gear.
Russell Shaffer
Klamath Falls, Oregon
« Reply #3 on: May 12, 2010, 01:57:52 PM »
you would also need to have the foot pedal out a ways from the centre of the circle - so you would need to release the model and step back into the circle - otherwise the pedal is a trip hazard.
Offline Richard Grogan
« Reply #4 on: May 12, 2010, 05:49:02 PM »
Use a garrage door opener! 12V alarm or deerfeeder battery(to run the receiver and coil of a 12V solenoid/relay for the release mechanism.Piece of cake, just put your opener in your pocket, pick up the handle with thong on, and press the button. It's really not that difficult.You can get the opener at Home Depot (Genie Controls), the battery at a sporting good chain that sells deer feeders. The solenoid/relay for a feeder might work,or from a car stereo place that sells and installs alarms..The battery will give your stooge extra weight too.Use your imagination! Now that would be a HOT setup! LOL  LL~
Long Live the CL Crowd!
                  AMA 85745
« Reply #5 on: May 12, 2010, 06:39:51 PM »
Sounds like a good theory.  But the Sears garage doors systems I use in my house aren't all they cheap and I'm not so sure the reveiver doesn't use 110 VAC.
Maybe I you're intent on going electronic, a cheap RC ARF would be a better starting point.  As a bonus, you could attempt to fly it until the airframe is used up.
« Reply #6 on: May 12, 2010, 07:05:29 PM »
My current setup is similar to Paul's. I think a pedal actuated release of the cord might work out using  a drummer's pedal. A friend might have  a used  one for me to try out.
I'm lucky to have one friend who flies Ukie to help launch. Since I'm retired, I'm ready to go whenever the weather cooperates. During the 60s and early 70s, there was always someone at the Ukie field. Now a days, I  primarily fly R/C Pattern - but having a good time again with ukie.
Thanks for your suggestions,
Frank
Offline W.D. Roland
« Reply #7 on: May 14, 2010, 02:23:17 PM »
I like the foot pedal idea!
So far no problem using hand release and then throwing it 10 or so ft away.
Radio operated is asking for interference to interfere!
If you do this use current R/C equiptement( narrow band,2.4, all that stuff....)
David
David Roland
51336
« Reply #8 on: May 15, 2010, 09:06:35 AM »
With the cord I use on my stooge, there is no throwing as it is kind of elastic.  When I reset for next flight I have to get it back from about 15 feet where I stand for launch.  By the way the cord is Ace Hardware day glo pink or was at one time. H^^
« Reply #9 on: May 15, 2010, 09:21:38 AM »
I quit throwing my stooge reel after I tossed it over the lines once.  I drop it gently and step back a little from the orange soccer cone that marks the handle and stooge reel.
Russell Shaffer
Offline W.D. Roland
« Reply #10 on: May 17, 2010, 01:36:54 PM »
I tend to wander around the pilot circle a bit so throwing the release handle 10ft away or so is good idea and currently the center of my circle is a 16in square concrete block so I wander even more than normal. The now missing airplane eating trees are evidence of how far one can wanderrrrr.
David
David Roland
51336
