  • July 08, 2025, 07:35:38 AM
Author Topic: Enya SS30  (Read 1484 times)
Offline Dave Swanson
Enya SS30
« on: June 02, 2017, 11:24:31 AM »
I am ready to spring for a new Enya SS30 but am dithering whether to go with the BB version or the plain bushing type.  Any thoughts on this choice?  I usually would just opt for the BB over the bushing.
AMA 32832
Re: Enya SS30
« Reply #1 on: June 02, 2017, 12:00:56 PM »
What are you going to use it for, and in?
Re: Enya SS30
« Reply #2 on: June 02, 2017, 12:15:28 PM »
Initially it will go in my RSM Ringmaster S1.
AMA 32832
Offline Bill Johnson
Re: Enya SS30
« Reply #3 on: June 02, 2017, 12:58:39 PM »
I'd go with the bushed engine to save weight. You will never wear it out and you won't need the .05 extra HP the BB version is rated at.
Best Regards,
AMA 350715
Offline Chris Brainard
Re: Enya SS30
« Reply #4 on: June 02, 2017, 01:11:35 PM »
I have the bushed version in my Ringmaster and am very pleased with it.
Chris
Online Fredvon4
  • Central Texas
Re: Enya SS30
« Reply #5 on: June 02, 2017, 01:30:58 PM »
I also, would opt for the bushed version...weight...and my experience with  several .35 5224s over 40 years old and not anywhere near worn out
In fact one always was fairly low on power and hot nose, so I chucked up the crank and progressively polished it with finer and finer diamond grits --- I doubt I ever did reduce the crank diameter ----but that engine now has well over 4 gallons of fuel through it and you would think it still new
I suppose I could have lapped the crank to the bushing.... but unsure of the best method, I just super polished the crank.... and let the rest of the engine break in over time.... and believe me ALL Enya's take a goodly bit of seasoning to be fully broken in!
If the new beautiful red head  Old skool .35 was not so expensive I would have one
Back to the Ring master S-1... even a porky one..... the Bushed 30 is probaly a good fit (IMO) while a good broken in Enya BB 30 would have much more Umph than needed---- and require unnecessary tail weight to haul around
Fred von Gortler IV
Re: Enya SS30
« Reply #6 on: June 02, 2017, 02:36:40 PM »
Plain bushed version ordered!  thanks for the input
AMA 32832
