  • June 18, 2025, 11:21:02 AM
Author Topic: Toothpicks or fence palings  (Read 1109 times)
Offline John Carrodus
« on: April 01, 2022, 02:00:00 PM »
What is the functional difference between skinny/narrow toothpick props and wide fence paling types?
Online Dennis Toth
Re: Toothpicks or fence palings
« Reply #1 on: April 01, 2022, 02:47:01 PM »
Basically, pulling power. For ships that are low drag (like speed ships) the thin/narrow blades are very efficient once they get going. For Stunt ships the wider or multi blade props bit better and haul the high drag heavier ships through the maneuvers. For electrics large diameters draw more amps then short ones and can be used to help manage battery pack size needs. You kinda start with what has worked for most fliers for the engine/plane you have as our baseline, then change from  there and see if your performance improves.
Best,   DennisT
« Reply #2 on: April 01, 2022, 06:19:35 PM »
You’ll get some bogus answers. I think the best way to see how prop characteristics vary is to go to mh-aerotools.de , get Javaprop, and try stuff.
« Reply #3 on: April 01, 2022, 09:19:23 PM »
   You won't know until you try them on an airplane. What works on one airplane/engine combo might not work on another. The best prop you can find for your airplane is the one that you tested with and that pulls the plane the best and gives best line tension. If you find the one that works the best, make sure you have some back ups!
« Reply #4 on: April 02, 2022, 01:02:03 PM »
Thanks guys for your thoughts and once again years of experience. I just can't seem to get my head around the difference between 10x4 wide paddle pop blade and a skinny 10x4. Surely the wide blade shifts more air and has better bite? But does that also mean it revs slower because of the greater load. What are the actual physics involved? I suppose at the end of the day we say "Who cares? Whatever works best ."
« Reply #5 on: April 02, 2022, 03:34:28 PM »
   The physics are largely the same as any other airfoil, but that's not very helpful. What is missing, particularly from hand or CAE programs, is that the feedback the engine sees during maneuvers will not be addressed. And that is one of the most important factors for regular engines.
   I also caution you about getting misled by ground RPM measurements - what it measures on the ground, i.e. "revs slower because of the greater load", can sometimes be *very misleading*. For instance a 10-6 will "spin slower" on the ground if you put in place of an otherwise identical 10-5 and leave everything else the same - but it takes much less shaft power in-flight at the same lap time - so it is much less load and less demanding of horsepower than a 10-5.
   That brings up the next wild misapprehension. The 10-6 requires less of the engine to go the same in-flight speed because it is better at transferring power from the engine to the airplane - which is the definition of "more efficient". Unfortunately a lot of people have been trained or led to believe that "more efficient" is the equivalent of "better" - which is possibly true if you have limited power, or if you goal is to go as fast as possible for a given airplane and maximum power.
    Back in the good old days, and for some of the "retro" engines and approaches today, you need to run as efficient a propellor as possible to make use of the maximum power. That's the problem, in many cases, for full-scale airplanes. You only have so much power, the engine (geared or otherwise) can only spin so fast at a the maximum power, so you choose a prop that gives you the best efficiency at the maximum shaft HP, so you go as fast as possible.
   With feeble engines like the ST46, Fox 35, etc, getting enough power was the primary issue, so highly efficient props were the norm, and you dealt with the  effects of it.
    Since the advent of schneurle engines (late 70's) and the knowledge of how best to use them (mid-late 80s), getting enough power to fly a stunt plane hasn't been an issue - you have far more power than you could use, the problem is using it up or suppressing it somehow, while taking the maximum advantage of it. So you typically use *extremely inefficient* props, completely different from before, and count on the efficiency changing with speed in a favorable way to maintain the maneuvering speed.
   This has completely transformed how stunt works, and how much performance you have.
    To answer your question directly, on 4-2 break engines (ST46, etc) wide-blade props increase the efficiency and the feedback of load into the engine. They usually work well in hot and calm conditions because you can use all the break you can get. In windy conditions, wide-blade props are notorious for encouraging "whip-up" for the same reason, your load feedback tends to be "out of phase" with the drag and dynamic wind effects, causing wild acceleration in some maneuvers (particularly the round loops).
    With narrow-blade props of nominally the same "load" and level-flight speed , you have the opposite effect, it gets wimpy in the hot air and is generally better in terms of whip-up.
   If you want to know what you need or might want to try in a specific condition, then we need more details. The question cannot be answered in a completely general case, because prop selection is mostly about how the engine responds, much more than how the prop works itself.
« Last Edit: April 05, 2022, 09:17:50 PM by Brett Buck »
« Reply #6 on: April 02, 2022, 03:59:05 PM »
Thanks Brett.
You have answered a lot of questions for me and raised a few new ones I hadn't thought of. That's what I love about this CL stuff, it's always opening new doors, a wonderful mix of art, science and experience. It is NEVER boring! Love it. Always something new to learn.
« Reply #7 on: April 05, 2022, 04:35:57 PM »
Thanks Brett.
An interesting thing to study is/are the APC propeller line. You'll notice that they have several very different looking prop designs, some with pretty wide blades with scimitar tips, while others of roughly the same size are radically different. Look at their 11.5 x 4, 12.25 x 3.75 and 12-4. The 12-4 looks like it would be good for self-defense in a dark alley, by comparison to the others. Yet, they all work very nicely for CL Stunt duty, if well matched to the engine and plane.  D>K Steve
