  • July 11, 2025, 01:16:07 PM
Author Topic: Sterling Piper Apache  (Read 2668 times)
Offline curtis mattikow
« on: December 18, 2018, 09:54:22 AM »
Going to have two pee wee 020's.
Re: Sterling Piper Apache
« Reply #1 on: December 18, 2018, 10:31:55 AM »
This is going to be a project worth watching.   D>K
« Reply #2 on: December 18, 2018, 07:43:34 PM »
 Neat project! What's the wingspan?
 (btw, you might want to restart this thread in the Building section)
« Reply #3 on: December 18, 2018, 07:59:55 PM »
23" span.  Moving along on this one quickly....
Offline Skip Chernoff
« Reply #4 on: December 19, 2018, 06:49:36 PM »
Good to see you here. Thanks for sharing your project.
« Reply #5 on: December 19, 2018, 07:14:31 PM »
I build a LOT(see my facebook page) but this is my first CL in many, many years.  Rather than just BS about AHC and AMA, I felt it would be good to contribute something actually substantial.
First coat of clear dope should go on tonight.
You'll be the test pilot!
Offline 944_Jim
« Reply #6 on: December 19, 2018, 09:18:39 PM »
Been watching on FB. I still can hardly believe this build is so fast! Duco, huh?
Is it clear, or colored? I picture something like rubber cement...I do t know why.
Will Duco do pottery too?
« Reply #7 on: December 20, 2018, 05:50:57 AM »
Yeah, I'm the world's fastest builder!  That and five fifty will get me a venti frappucino at Starbucks!
Not the BEST builder, but I have my moments...
Duco is clear.
Yes, it will fix that pottery vase you broke, and your wife will never know.
First dope coats laid on, just doing a little filling and sanding, then more clear doping.
Offline Ron Cribbs
« Reply #8 on: December 20, 2018, 09:47:28 AM »
Nice! Quick work too.
I am sure you are very familiar with Cox engines, but I thought I would mention a few things anyway.
The Pee Wee is a good engine, but....they are super finicky! Everything relating to the fuel tank must be air tight. To include: Venturi o-ring, backplate, backplate screws, crankcase to tank gasket, tank to backplate seal and NV . If anyone one of these is allowed to draw air it will run like garbage. It generally takes me a couple hours to set a pee wee up properly before use. Even out of the box they fail the tank pressure test.
Anyway, just thought I would mention it as evenly matched steady runs are a good thing on a twin setup, plus it looks like they are cowled in pretty well and might be a pain to remove.
Have fun with it!
Ron
« Reply #9 on: December 20, 2018, 11:40:04 AM »
Have fun with it!
Ron
Doped silver now over four coats of clear, silver will be a basecoat for yellow.  Or maybe it will be silver.  Dunno.
I have rebuild kits, new heads, and spring starters on the way for the pee wees.  Thought about aux tanks for better duration but they do not work well on pee wees.  Should have done two tee dees instead, with seperate tanks.  I just decided to replace the whole control system...I did the stock plywood bellcrank, balsa pushrod, and pins for the ends of the rods...it works, but...nah.  Right now I can swap it out, but not after the windows are in.
Oh...I made the fronts of the cowls removable with two teeny screws, getting the engines in and out will now be no problem.  Like you...I know how these wee pee wees are...
Offline Ara Dedekian
  • Ara Dedekian
« Reply #10 on: December 20, 2018, 02:33:28 PM »
        Curtis
           You got me digging through my old photos. 1960, twin Pee Wees, silkspan with brushed on dope. Have no recollection of flying it, probably because I couldn't get the engines running. I do remember GIVING IT AWAY!
        Ara
Offline 944_Jim
« Reply #11 on: December 20, 2018, 04:37:02 PM »
I'm digging this build!
Curtis, how are you handling painting plastics? I did dope over plastic on a couple of DPC Clones, and an original Scientific P-40 engine cowl. There is no guarantee that all were of the same styrene composition, but they glued just fine with liquid seam-following plastic cement.
The dope stayed on...for a little while. All plastic was sanded with 400 grit set or dry (new, not contaminated), and washed in hot soapy water.
I'm tempted to try sandable lacqquer, top coated with dope.
« Last Edit: December 20, 2018, 06:36:57 PM by 944_Jim »
Offline Dane Martin
  • heli pilot BHOR
« Reply #12 on: December 20, 2018, 06:32:13 PM »
Beautiful job Curtis!
« Reply #13 on: December 20, 2018, 07:31:34 PM »
Lacquer is dope.
I let some dope puddle inside the nacelles and it crazed the bottoms a bit. I know better if Han that. Not sure ortied about it flaking off the ioutsides...doubt this will get flown more than once or twice...
« Reply #14 on: December 20, 2018, 07:32:59 PM »
        Curtis
        Ara
Too awesome. I wonder when the last time someone built this kit before me, and wonder if I will be the last one to build one...
« Reply #15 on: December 23, 2018, 06:37:01 PM »
Going to be yellow with blue trim.
« Reply #16 on: December 26, 2018, 10:24:26 AM »
Blah blah blah apache blah blah.
« Reply #17 on: December 27, 2018, 08:58:14 AM »
That is looking good and should be an attention getter while it is flying.  I know the Black Widow got me a first place at a contest and got a lot of attention even though all I did was take off, level flight and landing. H^^
« Reply #18 on: December 27, 2018, 09:30:06 AM »
I'd like to do a sterling black widow for RC.
« Reply #19 on: December 27, 2018, 06:16:34 PM »
Pretty much done.  WAitingn for rebuild kits for the engines.
