If you use the ones that Mike suggested, make sure that you really beef up the mounting point to spread the loading. All the control surface loading is coming through that small plastic mounting plate. These were standard issue on Ukie 35's and I had one work its way through the balsa at an inopportune moment resulting in one of those sub-grade pullouts. Other than that, they're great and infinitely adjustable.
