  • June 22, 2025, 12:32:53 AM
Author Topic: DIY air compressor to paint your planes  (Read 1460 times)
« on: February 17, 2017, 12:32:03 PM »
You got to give this guy a E for effort. :)
Re: DIY air compressor to paint your planes
« Reply #1 on: February 17, 2017, 02:15:46 PM »
Uh.....just "Wow!"   LL~ Steve
Offline Jim Svitko
« Reply #2 on: February 17, 2017, 04:26:23 PM »
I suppose whatever it takes to get the job done.
I spent a year in Thailand while in the Air Force.  This was the mid-70s.  Back then, gasoline cost something like 80 cents a gallon there.  That was probably more than what most of them made in a day.
I saw all sorts of home made devices and work-arounds because people had no money.  Buying something new was almost out of the question or even getting something fixed.  The things I saw on motor vehicles would have you shaking your head.  Instead of an air filter, I once saw what looked like panty hose tied to the carburetor.  I don't know if he ever ran it because I would have expected it to melt.  Instead of a shift lever on a motorcycle, I saw a pair of vise grips clamped to the shaft.  It scared me to think what they did for a brake job yet I rode around quite a bit in the small pickups that were used as taxis.
Offline david beazley
« Reply #3 on: February 17, 2017, 06:30:17 PM »
I wonder how you say "Git 'er done!" in his native tongue!
AMA # 2817
Offline Larry Renger
« Reply #4 on: February 17, 2017, 07:04:29 PM »
No breathing spray mask? Where is OSHA when you need them?  LL~
Offline Wayne Collier
« Reply #5 on: February 18, 2017, 12:17:54 AM »
That's ingenious. Two thumbs up!
Nothing that elaborate, but when I was a kid dad pulled the compressor out of an old refrigerator to use as a vacuum pump.  A hose on the output line powered a badger air brush and kept bicycle tires full of air.
Offline Astropuppy
« Reply #6 on: February 18, 2017, 02:10:29 PM »
thats crazy.
Astropuppy
Offline Phil Krankowski
« Reply #7 on: February 18, 2017, 07:23:28 PM »
That is awesome!  It appears to be a fan motor, connected to the wheel end of a hand-crank grinder.  The grinder handle is driving a bicycle pump to a wheel which is an air tank.  The sprayer is piped in by puncturing the rubber of the wheel.  Ingenious!
I would not want it, but I am glad to see someone came up with it.
Phil
