Below are the rules for the starting procedure for stunt in FAI, copied straight from their site:
But I have a question.
Judging by the rules, if you forget to signal the judges that you are starting the motor, the flight time starts from when the motor fires up. Does this mean that you don't have to signal the judges and your 7 minutes starts from when the motor starts?
Technically this must mean that if you are worried you won't get a fast start, don't signal the judges and just wait till it fires (within the 3 minutes preparation time) because then your 7 minutes flight time will start....Surely not!!!...But check it out as that's what it says.
Am I missing something or is this another rule that need fixing as I thought if your motor starts before you signal, you can either stop the motor so that you
can signal, or just call an attempt.
The only points that get deducted are the 10 points for starting within 1 minute. ( 4.2.15.2 )
4.2.13
Starting procedure.
a) Each competitor shall be allowed 3 minutes preparation time to enter the circle, to place his model aircraft at the selected starting position, to position the judges and to prepare his motor(s) for starting.
b) The competitor may choose to start, warm-up and stop his motor(s) during the preparation time, and he must inform the timekeeper if it is his intention to do so.
c) Immediately after the preparation time he shall be allowed a 7 minutes flight time in which to complete his manoeuvres.
d) The preparation time shall start when the competitor is officially called to perform his contest flight.
e) The timekeeper shall signal the beginning of the preparation time to the competitor and the judges.
f) The preparation time shall end and the Flight time shall start when:
i) The timekeeper registers that the 3 minutes preparation time has elapsed.
ii) The competitor gives a clear hand signal to the timekeeper, indicating that he is ready to start his motor(s).
iii) The competitor starts his motor(s) without giving a clear signal to the timekeeper.
iv) The competitor starts his motor(s) for warm-up without receiving permission from the timekeeper.
g) The timekeeper shall signal to the competitor and the judges when the flight time starts. If no hand signal is given by the competitor prior to starting his motor(s), or he starts his warm-up without receiving permission, then the timekeeper shall notify the judges of this.
h) The timing of an official flight shall stop the moment that the model aircraft has come to a full stop at the end of the ground roll that completes the Landing Manoeuvre.
i) The competitor shall remove his model aircraft, lines and handle from the flight circle immediately after he has completed his flight.
