  • July 06, 2025, 03:20:14 PM
Author Topic: Stalker .76RE  (Read 5293 times)
Offline Gerald Schamp
Stalker .76RE
« on: February 05, 2016, 05:47:45 PM »
Just received a new Stalker .76RE from Tom Dixon. Beautiful engine, can't wait to get into the new build. Tom has great service, turn around time is 5 days, unless your bank doesn't recognize an out of state purchase. Suggestion, if you are purchasing something out of state or country, let your bank know ahead of time, so they don't put a hold on your card.  LL~
John Leidle
Re: Stalker .76RE
« Reply #1 on: February 05, 2016, 08:58:29 PM »
    Hey Gerald,
   I bought a Stalker .81 RE a few years back & and am now running it quite a it. I may get another.   I also picked up a Stalker .51 from Tom last November  great service .  I hope to see a little more  you this season. I've always looked up to you as a Master Builder & a very well seasoned , experienced pilot. Not to mention watching you fly.
   I find the Stalker to be a very under control power system.  Very steady , run it as rich as you want no burps or coughs in the verticle 8 .Just a perfect engine for me.
      Maybe we will see you in Portland in April , John
Re: Stalker .76RE
« Reply #2 on: February 05, 2016, 09:33:56 PM »
What prop are you running on the .81? I am looking for a 13 x 5 Bolly three blade, got one stashed away ?
Offline Walter Hicks
Re: Stalker .76RE
« Reply #3 on: February 05, 2016, 09:43:48 PM »
Gerald, I have a Stalker 76 SE. This is a low RPM high torque engine. It requires large props with pitch. At least 13-14 inches and at least 6 p
 using the Yatsenko Props I get from Kaz . 13.4x6.5 or so. 7000+-rpm nice steady four cycle I flew one in a clunker profile 72 + oz no problem,
the run characteristics are very different from PA , Jett ETC. I used 15% Byrons Heli Fuel all synthetic 21% oil with 3 head gaskets.
I may have used more head gaskets I have to check. Like the motor smooth, quite.
John Leidle
Re: Stalker .76RE
« Reply #4 on: February 05, 2016, 09:46:38 PM »
   Gerald,
  I went round & round on the .81 props , in the end I did exactly what PJ & Randy Powel  told me to do in the first place. I'm using a 12 - 8 to a 13 - 8
  low rpm 6100 to 7000 RPM. I buy Master Airscrew wood props & true them up & undercamber them.. I have repitched my Eathers too  . If I find something close to what you are looking for I'll let you know .  I found my .81 just wont rev but with its smoothness & low end torque it works fine ( also quiet).
John Leidle
Re: Stalker .76RE
« Reply #5 on: February 05, 2016, 09:50:54 PM »
  I did as Walter says... added 3 head shims when new I had trouble flipping it over .  I think the .76 &  .81 are similar. As a safety note   mine starts in reverse often.       John
« Last Edit: February 06, 2016, 12:41:08 AM by John Leidle »
Offline Dane Martin
  • heli pilot BHOR
Re: Stalker .76RE
« Reply #6 on: February 06, 2016, 11:00:28 AM »
Hi Gerald! I don't know anything about the prop size you need, but if you check out eliminator props in the vendors corner, you'll see Steve Wilk makes all those size CF props two or three blade. I gotta order some from him for my ro-jett. But i ordered a boat load of 1/2A speed props from him. They really are sweet.
Good luck! Hope to fly with you one day
Re: Stalker .76RE
« Reply #7 on: February 07, 2016, 11:10:50 AM »
Thanks guys for info, low revs is what I am looking for, would like to be able to run big three blade is possible. Engine, but wooden two blade is fine too. If I have to go to CF to get what I want then that's okay, not my favorite set up, but in order to get the right set up working then, I follow the map :). Thanks Dane for the reminder that Steve Wilks does those props also, I had forgotten. Anyhow again, thanks for the feedback. Oh and John, thanks for the kind words, but now I haven't flown for so long that I'm sure there will a few moments of amusement that you will see as it scares me to death. Thanks again all.
Re: Stalker .76RE
« Reply #8 on: February 07, 2016, 11:16:42 AM »
One more question about the .76RE, how big a fuel tank are you running, and are they plastic or metal? Tom Dixon has gotten Brodak's to make a 2 1/4" wide tank for these bigger engines, but need to know what size, about. The only restriction for size is the distance between the header neck and the motor mounts, its about 1/14" so a big thick tank would be a problem. OH and last, (this time :), do these engines run okay on regular uniflow, or do they need muffler pressure?
Re: Stalker .76RE
« Reply #9 on: February 07, 2016, 11:21:10 AM »
Gerald,
when it comes time to start aquiring props, get ahold of me for wood props,, I probably have a good number of Revups and others in the range,,
Re: Stalker .76RE
« Reply #10 on: February 07, 2016, 12:01:06 PM »
Will do, thanks Mark. BTW I took that JPG copy to a Blue Print Shop and they said it can be printed up to about 60 inches long because the resolution is so good. Ih ad them make me a 24 x 36 print and it fantastic. Anyhow, on with show.
Re: Stalker .76RE
« Reply #11 on: February 07, 2016, 12:47:24 PM »
THat is encouraging, I look foward to helping see this through with you, it will be an awesome project
John Leidle
Re: Stalker .76RE
« Reply #12 on: February 07, 2016, 06:01:43 PM »
   Gerald,
  Since I run my .81 quite rich wih .327 venturi at low RPM I  using over 7 ounces I'm not sure the precise time if you want it I can get for you on Wednesday.   I got my tanks fro Eric Rule I use his tanks that are something like 2.25 wide 1.5 high at various lengths. I order them as kits.  My muffler doesn't interfere with the tank . I use All Synthetic fuel & high nitro. No muffler pressure it runs as good as anything there is.  And again  exersize safety & caution when starting them  mine start backwards all the time.  Also unifo.
John Leidle
Re: Stalker .76RE
« Reply #13 on: February 09, 2016, 05:30:27 PM »
  Gerald,  I took the plane out today & checked the time from start to shutoff it was 5:38    7.5 ounces of fuel.  Others may have other results.
Re: Stalker .76RE
« Reply #14 on: February 09, 2016, 11:07:46 PM »
Thanks John, Tom Dixon recommended synthetic fuel, little or no Nitro,depending on the needs of the plane. Dave Royer uses all synthetic fuel with no Nitro in his Magnum with the Stalker .60 and has good results. He had a time fiddling with compression, props and fuel before it finally settled down, but now its real workhorse. So I guess when I get that far, I'll try one and maybe all the suggestions posted here and from Tom and Dave and see what it takes to make this beast run.
I will check with Eric Rule about tanks also. I'm guessing a 2 1/2" wide tank, 1 1/4" deep, about 6 inches long should be enough for starters, right?
Re: Stalker .76RE
« Reply #15 on: February 10, 2016, 09:56:35 AM »
That tank is just over 9.5 oz.  Do you really need that much fuel to fly the pattern???
Re: Stalker .76RE
« Reply #16 on: February 10, 2016, 01:31:11 PM »
Hi old friend!
May I ask the price of the .76RE as delivered by Tom??
John Leidle
Re: Stalker .76RE
« Reply #17 on: February 11, 2016, 12:57:27 AM »
  Gerald ,
 I have a  5.5" long tank in my plane I do   run rich so a 6 "   tank might work.
