  • July 07, 2025, 10:21:29 AM
Author Topic: ST51 NVA  (Read 1993 times)
Offline Phil Coopy
ST51 NVA
« on: June 29, 2006, 10:16:41 AM »
When replacing the NVA in a FOX35 with a ST51 NVA should I turn the spraybar down to the diameter of the FOX35 spray bar or will it work as it comes out of the package.  The ST51 spraybar installed looks as though it reduces the venturi area quit a bit.
Phil
Re: ST51 NVA
« Reply #1 on: June 29, 2006, 10:50:05 AM »
Hi Phil
If you want the same  power , break, and have the motor act  the same  you will need to turn down the ST spray bar
Offline Phil Coopy
Re: ST51 NVA
« Reply #2 on: June 29, 2006, 02:08:58 PM »
Thanks Randy! Thought there might be some secret trick burried there.
Re: ST51 NVA
« Reply #3 on: June 29, 2006, 02:29:39 PM »
well one  trick is  to  use  a  PA stainless  FOX 35  NVA.
another is you can just  file  the  sides of the  ST  flat  instead of turning it down,  when you turn down the  Brass  st  to  127 thou   it normally breaks  when you tighten it
Offline Phil Spillman
Re: ST51 NVA
« Reply #4 on: July 01, 2006, 08:46:28 PM »
Hi, Here's another idea! If you just use the ST NVA as supplied you can then determine if you need to do anything else! I have used a non adjusted ST NVA in Foxes without noting any difference nor detriment! So my thought is to try the thing and then make up your mind! Phil Spillman
Phil Spillman
Offline peabody
Re: ST51 NVA
« Reply #5 on: July 01, 2006, 09:00:09 PM »
I'm wondering why the Fox isn't used?
Offline Jim Thomerson
Re: ST51 NVA
« Reply #6 on: July 02, 2006, 07:33:25 AM »
Back in the 70's-80's, I could not get consistant runs with the flat-end Fox NVA.  I installed a ST NVA and intended to hog out the venturi, but never got around to it. ::)  I was, on several occasions, accused of running an ST 46, so I would suggest try it stock, and then modify if you think it needs it.  If you do, suggest you  file the sides of the spraybar or hog the venturi.
