Since my last post regarding my order from NB I've discovered some other flaws. Some of the wood is peppered with small holes, like pin holes. Very perfect little holes, as though they were drilled, or the wood was hit with a laser. The holes run in random directions; with the grain, across the grain etc. One 1/2" piece that is now the fuse, has what appears to be a small blue plastic plug. I didn't notice it until I started sanding. Very odd.
And I did take the advise given by many and emailed National Balsa regarding the issues I had with my order. That was nine days and as yet no response.
No problem using the wood as I'll fill the holes and paint over the plug, but I'm wondering what could have caused the holes, and why the "plug"? Does this happen with any frequency? Am I to picky?
Brian
