  • June 16, 2025, 07:40:33 PM
Author Topic: Brodak 40 loose needle valve  (Read 742 times)
Offline Colin Bell
« on: September 14, 2020, 12:03:56 PM »
I'm starting the break-in of my Brodak 40. With the needle valve open enough for a 2 stroke run, it's loose in the spray bar. How do I get it to be a firmer friction fit ? It's wobbling about a bit at the moment.
Online Jim Hoffman
Re: Brodak 40 loose needle valve
« Reply #1 on: September 14, 2020, 01:36:35 PM »
There is a collet on the spray bar that allows one to adjust how much torque (rotational friction) it takes to turn the NV.  Is that what you are talking about?
Or----------
Is the spray bar loose in the engine case?
BTW - the break in ought to start with fast 4 cycle runs, small prop (9-4) to not load the motor.
Offline Colin Bell
« Reply #2 on: September 15, 2020, 09:40:01 AM »
Thanks Jim, I didn't know about the adjustable collet. I'll try it out. Cheers, Colin.
