  • July 03, 2025, 02:10:16 PM
Author Topic: Help!!! Pampa says I am not authorized to use this resource - FIXED !!!!!!!  (Read 2278 times)
Offline Walter Hicks
Hi, I could use some help, when I log on to the PAMPA website and try to access Stunt News it says I am not Authorized to use this resource. I have
confirmed that my dues were sent and that I am a member. I thought that if I purchased the Paper version and first class mail that I could also access the
web version of Stunt News? Any help would be appreciated.
« Last Edit: March 16, 2017, 08:33:45 PM by Walter Hicks »
You should have access Walter, are you sure you are logged into the site, I know that if you are not logged in, you wont have access.
THere should be a link to the webmaster, perhaps your log in expired if you were a little late sending in your membership?
I wlll see if I can reach out to some of the other persons
Walter I too get the same.  It's not you...
Not late sending in the membership. Not a huge problem as I will get the paper copy soon. I really appreciate all the work that goes on getting the
Stunt News out.
Offline Chris_Rud
Walter and Dave, check again. I fixed the issue on your accounts.
-Chris Rud
Walter I got that also . If you look under the picture of the mag on the left side there is a link to down load the magazine.
Wow!!!! Thanks Chris for your very prompt assistance. Your work is very much appreciated .
Offline tom brightbill
Chris,
Same problem here. The home page greets me, but that's as far as I can go.
Thanks in advance,
Tom Brightbill
AMA 34849
Offline Mike Bufkin
Me too
Thanks for the fix Chris!
opps
Ed Ruane
« Last Edit: March 17, 2017, 11:25:05 AM by EddyR »
Offline Chris_Rud
Chris,
Thanks in advance,
Tom Brightbill
Tom Try now you should be good to go.
-Chris
Offline Chris_Rud
Me too
Mike your is fixed now also. Try and let me know.
-Chris
THanks Chris,, you da man
-Chris
Yup, perfect! Thanks again!
AMA 34849
Offline Chris Belcher
me too
Offline Chris_Rud
me too
Hi Chris, give it a try now. I updated your user.
-Chris Rud
Offline Brian Massey
    • California Car Clubs
Maybe you're just not authorized to see a picture of yourself on the cover?   LL~
Brian
AMA 55421
Madera, CA
Offline Mike Bufkin
Thanks Chris !!!!
