CLICK HERE--><--CLICK HERE
Spinner lip?
Started by Paul Taylor, September 11, 2026, 11:43:28 AM
Previous topic - Next topic
0 Members and 2 Guests are viewing this topic.
Paul Taylor
I'm just curious if this lip on the spinner is really serving a purpose other than making sure the spinner is lined up as you screw it down?
I'm making one and I put on the model but if it's not needed I would like to delete it.
I will have to post a few pictures below for reference. Sorry for the multiple post but TapTalk only allows one photo per post.
My Therapy involves Balsa wood and bad decisions.                               https://www.wpmpa.com
Everyone becomes a memory. The question is: will you be a good one or a bad one?
Kindness echoes. So does cruelty. People remember both.
Paul Taylor
Paul Taylor
Paul Taylor
Michael LeGate
The F/F folding blade setups don't look like they have a backplate at all. I've had older Williams Bros spinners deform at high rpms with the skirt unsupported at the crank end. A large stunt prop at moderate rpms might be ok.
Creative Creative x 1 View List
Mark wood
Is the reason you ask because of the less than perfect fit to the spinner backplate due to a small radius in the corner of the lip overhang? Are you using support of any kind there while printing? Unsupported overhangs are hard to make nice parts without using support material. For PETG the best is PVA. My perspective is that it looks pretty good to me for a 3D print.
I would be concerned about the centrifugal loads on the spinner without the lip. The unsupported rim places more shear on the layers. The inter layer strength is much lower than the in path strength. I always design 3D parts such that the printing path and load path are the same. Or at least I try to.
If you have a lathe, I would simply use a cutoff or square profiling tool to postprocess the lip and square the corner a bit. You could 2D print a holding fixture so you could chuck onto it with the lathe and then turn the corner nicely. PETG actually machines fairly nicely. I make all kinds of tools and fixtures for parts I am machining.
Life is good AMA 1488
"Physics is like sex: sure, it may give some practical results, but that's not why we do it." – Richard P. Feynman
Take off's are optional. Landings are mandatory, it's only a question of quality.
Paul Taylor
Thanks Mark
It started with a Spinner file I got from Page. It's a 3 blade "Igor" spinner that has a trench in the bottom and then a ring it printed to fit the trench creating the lip. It was said it fits Igor back plates. I have not seen it. The backplate I have has a spinner with the lip. I can print it in the part the take a small sanding stick and clean the tree droppings off. It's a bit of a pain so was asking if it really serves a purpose. Sounds like the answer is yes.
Mark wood
Quote from: Paul Taylor on September 11, 2026, 01:38:58 PMThanks Mark
I think the answer is yes. I could be wrong but the cost of a failure could be quite high. Shedding a peace of the spinner could hit a blade and cause some significant vibration. Or you could get lucky and it just shakes some. Or maybe it works and you just have that nagging doubt that hangs in the back of your head.
Igor's approach is solid. Me I'm a bit on the lazy side and just pay Lucien $7 for an airflow spinner. I save my design and printer work for things I can't buy cheaply or at all.
Howard Rush
I make spinners for Igor props. I use Great Planes or Gemfan backplates. I print the spinners from ABS flat on the base with a groove for the aforementioned ring. Maybe that's the file you got from Page.
I'd worry about the stability of a long spinner. Be sure to be at the other end of the lines when the motor starts.
Paul Taylor
Not sure why the spinner looks so long. It's not much taller than a DuBro. I'll add the ring.
Paul Walker
I like your spinners shape.
How much does your printed cone,  backplate  and screws weigh?
What is the backplate diameter?
Brett Buck
Quote from: Howard Rush on September 11, 2026, 03:37:03 PMI make spinners for Igor props. I use Great Planes or Gemfan backplates. I print the spinners from ABS flat on the base with a groove for the aforementioned ring. Maybe that's the file you got from Page.
  Exactly if you don't support it at the rear, it is just hanging from the spinner nut. I would think it would be very prone to whipping around at the rear.
Page Peterson
Paul, my 1.5" spinner used a Bad Ass 1.5" spinner backplate. The spinner fit Igor 3 blade props. Page
Howard Rush
Sorry for taking credit for your spinner, Page. Cool you can fit that prop in 1.5".
I think the BadAss backplates are same as Gemfan.
Howard Rush
Paul T., What's the groovy red stuff from which you made the spinner?
Paul Taylor
The spinner is held on with 2 M3x10 screws. The original spinner had aluminum M3 screws. I will get some. I made the slots for the prop over size for the APC so it would fit a Wooden BA prop. Going to try one on the plane.
The material is Silk PLA. From a few feet away the spinner looks like it's anodized aluminum.
@Paul W- I will get a weight when I get home from the flying field today.
Paul Taylor
The spinner weighs 8g, the backplate is 7g.
Paul Taylor
Quote from: Brett Buck on September 11, 2026, 07:01:06 PMExactly if you don't support it at the rear, it is just hanging from the spinner nut. I would think it would be very prone to whipping around at the rear.
Two 3M screws hold it down at the rear. And a small lip around the brim.
Paul Taylor
Quote from: Paul Walker on September 11, 2026, 06:17:14 PMI like your spinners shape.
The Cone is 8g the Backplate is 7 grams and my scale show the screws at 0g.
The backplate diameter is 1.25 in. Cone is 2 in tall.
Paul Walker
Quote from: Paul Taylor on September 12, 2026, 09:43:58 AMThe Cone is 8g the Backplate is 7 grams and my scale show the screws at 0g.
Thanks. Nice and light!
Like Like x 1 View List
realSteveSmith
Quote from: Paul Taylor on September 12, 2026, 09:43:58 AM...my scale show the screws at 0g...
Where can I buy these?  I bet they're expensive.
Funny Funny x 1 View List
AMA 175438
Paul Taylor
Quote from: realSteveSmith on September 12, 2026, 11:58:56 AMWhere can I buy these?  I bet they're expensive.
The scale was a gift but I think it's rude if I ask how much it cost. 🤣
Page Peterson
Howard, I based my little one off your idea for the backplate and the ring to join them.  Thanks! It worked very well. Page
realSteveSmith
Quote from: Paul Taylor on September 12, 2026, 01:05:50 PMThe scale was a gift but I think it's rude if I ask how much it cost. 🤣
I was more interested in the weightless screws than the magic scale.
AMA 175438
Paul Taylor
Quote from: realSteveSmith on September 12, 2026, 06:48:24 PMI was more interested in the weightless screws than the magic scale.
I know. I was playing along. 🤣
