CLICK HERE--><--CLICK HERE
Spinner lip?
Started by Paul Taylor, September 11, 2026, 11:43:28 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Ty Marcucci
Hi Paul.. It seems the lips only function  is for line up during assembly of the spinner..I'd leave three tabs to assist in line up. FWIW
Agree Agree x 1 View List
Ty Marcucci
Lauri Malila
Don't forget that with 10000rpm the centrifugal acceleration on ø2" surface is about 2800G (if my calculation is correct..), personally I woud like to have something that locks the cone to a given radius at spinner backplate. L
Paul Taylor
Quote from: Lauri Malila on September 13, 2026, 09:28:20 AMDon't forget that with 10000rpm the centrifugal acceleration on ø2" surface is about 2800G (if my calculation is correct..), personally I woud like to have something that locks the cone to a given radius at spinner backplate. L
So two cap screws into the backplate are not as good as one cap screws through the tip into the prop nut?
My Therapy involves Balsa wood and bad decisions.                               https://www.wpmpa.com
Everyone becomes a memory. The question is: will you be a good one or a bad one?
Kindness echoes. So does cruelty. People remember both.
Howard Rush
1/12 ft. • (10000 RPM • 2pi/60 (radians/sec)/RPM)2 • 1G/(32.2 ft/sec)2
Looks like about 2800 Gs. Wow.
Howard Rush
Quote from: Paul Taylor on September 13, 2026, 01:06:27 PMSo two cap screws into the backplate are not as good as one cap screws through the tip into the prop nut?
Either would hold the lip in the groove. One in front might be better for an aluminum spinner. I prefer three in the base for my short, printed plastic spinners, despite the bother of locating the prop. I like the looks of the holes in the side of the spinner better, too.
Like Like x 1 View List
Paul Taylor
Quote from: Howard Rush on September 13, 2026, 01:47:53 PMEither would hold the lip in the groove. One in front might be better for an aluminum spinner. I prefer three in the base for my short, printed plastic spinners, despite the bother of locating the prop. I like the looks of the holes in the side of the spinner better, too.
What material are you using Howard?
Howard Rush
Quote from: Paul Taylor on September 13, 2026, 02:06:44 PMWhat material are you using Howard?
ABS, but I might use PETG next time.
Mark wood
Quote from: Howard Rush on September 13, 2026, 01:37:13 PM1/12 ft. • (10000 RPM • 2pi/60 (radians/sec)/RPM)2 • 1G/(32.2 ft/sec)2
That's why us turbine powerplant guys don't like standing next to running turbines. I've seen the turbine and the damage done....
Life is good AMA 1488
"Physics is like sex: sure, it may give some practical results, but that's not why we do it." – Richard P. Feynman
Take off's are optional. Landings are mandatory, it's only a question of quality.
Howard Rush
Quote from: Mark wood on September 13, 2026, 04:02:26 PMI've seen the turbine and the damage done....
A little part of it in everyone
Paul Taylor
Mark wood
Quote from: Howard Rush on September 13, 2026, 05:28:02 PMA little part of it in everyone
That's kind of the blade release scenario such as a bird strike. For a rotor burst it's much worse. The turbine rotor generally breaks into three pieces and scatters. When we do a rotor burst analysis for certification we assume those fragments have infinite energy. Think of a 15 - 30 pound disk spinning at 45k RPM breaking into 3 5 pound pieces. Early in flight testing of a transport category aircraft, we had an engine have a failure like this. Fortunately no one was hurt. The one fragment found had exited the engine, bounced off of the tarmac, reflected, went through the other wing and was found a hundred yards away.  Anything in the plane of rotation is a gonner.
But I like the tune....
Ken Culbertson
I spent about 6 years working around running jet turbines....now you tell me! ~^
Paul Taylor
Ok Spinner in PETG. Doesn't look as kewl as the silk PLA.
I have some red PETG that will arrive tonight. We will see how it plays.
Paul Taylor
Correction the spinner is 1.75 inches. And yes it has the supporting ring.
Paul Taylor
Ok new PETG arrived today. All I can say is WOW!!!
I like this Ruby Red translucent filament. I think it looks better than the PLA.
The only problem with this spinners, I didn't randomize the seam. Next one is queued up stay tuned.....
Paul Walker
Quote from: Mark wood on September 14, 2026, 11:36:39 AMThat's kind of the blade release scenario such as a bird strike. For a rotor burst it's much worse. The turbine rotor generally breaks into three pieces and scatters. When we do a rotor burst analysis for certification we assume those fragments have infinite energy. Think of a 15 - 30 pound disk spinning at 45k RPM breaking into 3 5 pound pieces. Early in flight testing of a transport category aircraft, we had an engine have a failure like this. Fortunately no one was hurt. The one fragment found had exited the engine, bounced off of the tarmac, reflected, went through the other wing and was found a hundred yards away.  Anything in the plane of rotation is a gonner.
Similar to the DC-10 that lost all hydraulic systems but still managed to land in Souix City Iowa. An amazing number of people survived that incident.
Mark wood
Quote from: Paul Walker on September 17, 2026, 06:51:21 AMSimilar to the DC-10 that lost all hydraulic systems but still managed to land in Souix City Iowa. An amazing number of people survived that incident.
Yes. The rotor burst analysis stems directly from that accident. The DC10 hydraulic system was triple redundant but within the rotor burst ejection plane. The rotor fragment took out all of the hydraulic systems. The regulations weren't in place at that time and were put in as a result. The powerplants group has to fight a number of battles to protect the keep out zone and manage the system safety. In general the safety assessment takes years of work and we had a full time guy on it. Rotor bursts are rare but they happen. There was a DC9 I think had one and it killed at least one passenger as I recall.
While I worked at Allison / Rolls Royce we had a M250 let one go and it did damage in the cell. We also had a couple of T800 power turbines break off and "fall" out of the engine during initial development. One was in San Tan AZ and it rolled a couple miles across the desert. It was easy to find because it left a trail of debris behind. The other was in a round test cell and it sawed through all of the services, pipes, electrical and mechanical. It made a huge racket in the process and circled inside the cell for quite a while before stopping. Needless to say spinning chit shouldn't be taken lightly.
Paul Taylor
Well just in case I ever want to go bassackwards I made a reverse pitch copy. LOL
