  • July 02, 2025, 07:35:17 AM
Author Topic: Sig Nitrate  (Read 1228 times)
Online James Mills
Sig Nitrate
« on: January 22, 2008, 10:27:53 AM »
I got some SIG nitrate, can I use Brodak thinner?  If not what should I use?
James
AMA 491167
Online Crist Rigotti
Re: Sig Nitrate
« Reply #1 on: January 22, 2008, 10:32:27 AM »
I use Dupont 3608S thinner with my Sig Dope.
Alan Hahn
Re: Sig Nitrate
« Reply #2 on: January 22, 2008, 10:49:32 AM »
This is too easy. You should (of course) use Sig Thinner. ~>
This of course is even easier if you already have some. I bought a gallon during one of my visits to Sig for their annual CL contest.
Re: Sig Nitrate
« Reply #3 on: January 22, 2008, 11:11:21 AM »
3608S can't be beat for Sig, Randolph, (maybe not the Brodak Randolph, don't know about it as I've yet to use it) Cooper, and most lacquers rescued from spray cans.  I also use it for nitro-celulous lacquers - all brands.
Re: Sig Nitrate
« Reply #4 on: January 23, 2008, 11:12:49 PM »
I agree.  I use it in everything, and contrary to the fearful, I have not had a problem with it for over 15 years.  The planes way back built then still show no ill effects.  It even thins the 2 part urethane clears (per Sparky's instructions!).
