  • July 05, 2025, 11:41:29 AM
Author Topic: Spell Check  (Read 1457 times)
Online Doug Moisuk
Spell Check
« on: April 21, 2023, 10:24:36 PM »
Does anyone else have trouble with the spell checker?  When I use it my message or post disappears.
Doug Moisuk
MAAC 3360L
Re: Spell Check
« Reply #1 on: April 21, 2023, 11:26:37 PM »
 Step one is just knowing how to spell.  ;)
Offline RC Storick
Re: Spell Check
« Reply #2 on: April 22, 2023, 05:08:31 AM »
just sit back and drink some "cofefee" and use Garmmarly browser app. It auto-corrects and it's free.
Offline John Rist
Re: Spell Check
« Reply #3 on: April 22, 2023, 07:55:31 AM »
Actually it's KAUPHY   LL~
Online Clint Ormosen
Re: Spell Check
« Reply #4 on: April 22, 2023, 09:14:52 AM »
Hookt on fonicks wurkt fo mee!
Re: Spell Check
« Reply #5 on: April 22, 2023, 10:35:41 AM »
The Stunthanger spell check has not worked for me for a year or more.
I just do my best.
When I am wrong somebody posts a correction.
Offline Dwayne Donnelly
Re: Spell Check
« Reply #6 on: April 22, 2023, 12:07:32 PM »
Re: Spell Check
« Reply #7 on: April 22, 2023, 12:16:25 PM »
   I don't think it has anything to do with Stunthangar, that is a browser function - what browser are you using?
Offline John Carrodus
Re: Spell Check
« Reply #8 on: April 22, 2023, 01:52:08 PM »
Most stuff I write is full of mistakes because you Yanks can't spill korectly! n1
And Sparky - the drink is -Coughy! LL~
Re: Spell Check
« Reply #9 on: April 22, 2023, 02:24:29 PM »
Most stuff I write is full of mistakes because you Yanks can't spill correctly! n1
And Sparky - the drink is -Caughey! LL~
After all, we are two peoples separated by a common language.
My spell check fixed it just fine.
Re: Spell Check
« Reply #10 on: April 22, 2023, 05:20:38 PM »
  Most web sites seem to have their own spell check, and they work differently as far as I can see. If I misspell a word, it gets underlined in read, and if you right click next to it, it will show possible corrections. most work really well. On my computer I use Chrome for a browser, and anytime I am under it's watchful eye, and I happen to invert a letter or two, most times it has NO IDEA what I'm trying to type!! LL~ LL~ I spell way better that Chrome does!!My problem is just intermittent dyslexia, and I just spelled both of those words correctly!!
Re: Spell Check
« Reply #11 on: April 22, 2023, 10:34:18 PM »
the crankey olde keybooards misspell , at times . or fingers cross . or you dont hit it write .  :-X .
But we have english and american spelling , and spell check will correct aero terms to disco bunny trash , or reinterprate what it doesnt know .  %^@ perhaps its female .
Online GallopingGhostler
Re: Spell Check
« Reply #12 on: April 25, 2023, 08:45:56 PM »
I remember using Wordstar 3.0 on a Xerox 820-II CP/M-80 system. It was considered a business system, but became available at the Xerox Surplus Store in I think the Dallas area by mail order, back in the latter 1980's. All surplus, used equipment and software. Ran in 64 KB of memory on 180 KB single sector disks, Z-80A processor at a whopping 4 MHz clock speed handled the Intel 8080 code that most software was encoded in. I bought stuff to use at home there, because of the clearance prices. When new, systems were a couple thousand dollars.
Later upgraded disks to double sided double density 360 KB. Had both 8" floppy drives and 5.25" floppy drives. Required installing a special interface card for DSDD. Later, upgraded to 16/8 with 80186 coprocessor board inside the expansion chassis to run 3 OS's, CP/M 86, CP/M 80, and generic MS DOS 2.0. Installed a 5.25" MFM 10 MB hard disk, but had to modify the 820-II's BIOS in 16/8 mode. Xerox was hard coded for 360 cylinders and 4 heads. Used Miniscribe I acquired was 720 cylinders and 2 heads. Also patched the partition and formatting software to take into account the differences, but got it all to work.
Anyway, probably too much information for most.
Came with a separate spell checker called Spell Star. Things have changed quite a bit since then. But, I observe, although we seem to be so called technology smart, overall, we seem to accomplish about the same amount of work with manual methods back then as we do now with all the tech. Don't think we are really any further along than before. Really.
Re: Spell Check
« Reply #13 on: April 27, 2023, 01:43:30 PM »
If I don't think a word I type looks correctly spelled, I copy and paste it into Dictionary.com and find out. If I'm wrong, I may have to try some variations to get it correct, but I do that.
What bugs me is that it used to be common for the hardcopy dictionary to show several spellings, with one being called best, and one or two other spellings called acceptable. Not so anymore, at least with the online dictionary. I still tend to get tripped up by "practise" and "practice". Sorry about that. I think one is "best" and the other "acceptable".
I used to get the wiggly red line under misspelled words, but that went away with this newest computer. No idea why, but I figure it's probably Bill Gates' work. I might remember to ask my computer tech (son) sometime, or not. I did get fairly PO'd when it used to auto-correct "venturi" and persisted in changing it to "venture". But I also figured out how to save various semi-technical words like that, to stop its intrusions. Still not sure why I should have to correct the auto-correct. Probably has to do with modern generations tending to be such avid texters and scared of math, physics and science?
I have been a newsletter editor for a model club, a car club, and two fishing clubs, and always tried to appear halfway educated, so I paid some attention to grammar and spelling. I also took a class in "Business Letter Writing" at the U. That class, if you made a spelling or grammatical error on an assignment, you got an "F" on it. I tend to be a spelling nazi, because it shows me that some just don't give a fig and are 100% willing to show their laziness/ignorance. It is admittedly much easier to just not read those posts than to try and decipher them.  %^ Steve
Re: Spell Check
« Reply #14 on: April 27, 2023, 04:04:59 PM »
Still using the desktop motherboard home brew system from 2008 in Linux Ubuntu Mate, starts up fast, shuts down fast, especially using solid state disk drive now. Spell check depends on what country settings are, browser wise and app wise. If UK, AU, ZA, then spelling with be British. If US, then American. Autocorrect is suggestive, lets me change it.
Android cellphone is another story, seems to like to decide on spellings for you, so have to be more alert.
Personally, unless you are corresponding in a work setting on company business, I've never paid much attention to mispellings, more important one communicates. Even at work I emphasized with the techs, it is more important that you communicate your thoughts in writing, especially with inspection observations. You don't have a teacher looking over your work to chastise you for not using perfect English. For contract compliance issues, documenting is more important.
Some get wrapped up over the unimportant. Mike Reed in his now long gone Flame Warriors blog pointed out one type forum poster mw~ who goes after unimportant details.  LL~
Fortunately, we don't have such here, but have met that type on other forums.  :o
Re: Spell Check
« Reply #15 on: April 27, 2023, 04:42:28 PM »
I have been a newsletter editor for a model club,…
I enjoyed Steve’s newsletters, especially his creative apostrophezation.
