  • June 17, 2025, 12:35:37 AM
Author Topic: Brodak Rock Crusher Handle  (Read 1804 times)
« on: August 09, 2012, 12:40:39 PM »
Anybody using the new Brodak "Rock Crusher" hard point handle. If so, what's your opinion?
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Brodak Rock Crusher Handle
« Reply #1 on: August 09, 2012, 12:54:29 PM »
I have a couple and like them.. Some feel the weight is an issue but I don't notice any difference between it and a wood hard point when I'm flying.
Offline Garf
    • Hangar Flying
« Reply #2 on: August 09, 2012, 12:58:59 PM »
I have one. It fits my hand well. It is a little heavy, so it takes some getting used to.
« Reply #3 on: August 09, 2012, 01:16:57 PM »
The 4 stroke man has one. That means I gots to look into it. The issue of weight is irrelevant with the Saito 72. With the big block,you won't notice the weight-trust me.
Offline Steve Hines
« Reply #4 on: August 09, 2012, 04:07:45 PM »
I like mine alot, the weight is just a little more than may AMA watch on my other hand, it keeps me balanced. The plane still wants to pull it out of my hand and the plane is all most all the time above my hand so I can not tell what the weight of any handle is.
Offline Joe Connelly
« Reply #5 on: August 09, 2012, 04:19:05 PM »
I've got one and I think it's great. I am not a good flyer by any stretch of the imagination, but I can't figure out why the weight of the handle should make much of a difference. This handle is very well made and feels more solid than any other handle I have used. The hard point feature sure makes a difference in the feel.
Joe Connelly
« Reply #6 on: August 09, 2012, 05:09:52 PM »
Unless you are flying a 1/2A, I don't see why the weight would matter. If you are using a Saito 62\72 you won't feel the handle, that's for sure.
« Reply #7 on: August 09, 2012, 06:07:35 PM »
I have had one for a couple of years and it is fine on planes that have a good pull.
Offline peabody
« Reply #8 on: August 09, 2012, 06:49:55 PM »
Sorry.....but I have to believe that weight matters....
Paul Walker uses handles that he crafts himself of carbon fiber....because of the weight advantage...and he knows a thing or two about flying...
That said, the Brodak handle is pretty nice...has a BUNCH of adjustability and comes all finished and ready to use.....
Have fun!
« Reply #9 on: August 09, 2012, 07:18:02 PM »
A couple of guys in our club bought the "Rock Crushers" when they first came out, but I've noticed that they don't use them anymore. It's pretty much TED HANDLES across the board, tho some are scratch built copies.
When the line tension goes away due to wind or power problems, whatever, and landings...THAT'S when the weight matters most.  D>K Steve
« Reply #10 on: August 09, 2012, 07:39:18 PM »
D>K Steve
What are the differences between a "Ted Handle" and a "Rock Crusher"?
« Reply #11 on: August 09, 2012, 07:51:41 PM »
The TED Handle is (ergonomically) a copy of a Hot Rock, and being a kit, you make it fit your hand. There is a larger sized version for people with big mitts, but again, being a kit, you make it fit.
My (smaller sized) TED handles, with epoxy finish, safety thong and "rod wrap" grip tape, weigh 60 grams each. Can somebody weigh their big/little "Rock Crushers" and report back?  H^^ Steve
« Last Edit: August 09, 2012, 11:13:17 PM by Steve Helmick »
Offline Dick Pacini
« Reply #12 on: August 09, 2012, 09:09:50 PM »
The TED Handle is (ergonomically) a copy of a Hot Rock, and being a kit, you make it fit your hand. There is a larger sized version for people with big mits, but again, being a kit, you make it fit.
My (smaller sized) TED handles, with epoxy finish and "rod wrap" grip tape, weigh 60 grams each. Can somebody weigh their big/little "Rock Crushers" and report back?  H^^ Steve
I was told the Rock Crusher was a copy of the Hot Rock, hence the name.
AMA 62221
Offline Steve Hines
« Reply #13 on: August 09, 2012, 09:13:58 PM »
Got the scale out. Brodak R.C. 4.14 oz, Kaz wire 3.2 oz. Morris 3.32oz wire, hanger 9 1.97oz, EZ Just 1.72oz. Samantha fly's a kaz handle I fly the Brodak, I need to find her a lot lighter handle, if a oz or two is that big a deal with landings. I know I'm over 5 times stronger than her. There was no one that out landed her in begginer classes and not a lot in much higher classes. Think how good she would be!
Offline jim welch
« Reply #14 on: August 09, 2012, 09:41:45 PM »
I've got 10 of um but severly modified with balsa handle replacement and tennis grip/thong weigh 2.5 ozs with 4 screws locking the slide run all the way in /elongated slots.super light and comfortable.....Jimmy
AMA 89335
Offline Bootlegger
« Reply #15 on: August 10, 2012, 09:25:09 AM »
  Where can info on the Ted handle be obtained?  THNX
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Rafael Gonzalez
« Reply #16 on: August 10, 2012, 09:59:56 AM »
Totally agreed. The feeling of the lines as tension varies, is muffled by a heavy handle. I guess is a matter of getting used to it and having all the handles be the same. I have a plethora of Fast and Slow combat handles that I have used that were commercially available at the time along with F2D handles. Made my own and found them better. reason being that they were carved to a minimum and fitted to my cupped hand. Now I have tried the Brodack's plastic "Hot Rock" and found it heavy. I like it but will use it on hard pulling fast ships.
I have tried the REYCO hard point by the same people (Brodack). I LOVE IT!!! Light, sensitive and responsive as you wish. The number is SKU# RE-428 HP.
« Last Edit: August 10, 2012, 11:28:31 AM by Rafael Gonzalez »
