  • June 25, 2025, 04:08:27 PM
Author Topic: Brodak war birds  (Read 788 times)
Offline Bootlegger
Brodak war birds
« on: August 23, 2014, 11:55:21 AM »
 Of all the Brodak war bird profile models which one do you like best, and how did you come to this conclusion, also what engine are you using?
  I am looking at getting one for WWII stunt, so appreciate all the suggestions...
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Brodak war birds
« Reply #1 on: August 23, 2014, 01:21:24 PM »
The FW190 is my personal favorite, but it is generally believed that the Zero is the best flyer.
Offline dennis lipsett
« Reply #2 on: August 23, 2014, 02:34:36 PM »
I posted a response on the other forum which highly endorsed the Zero with an Evolution 36 for power.
dennis
Offline Balsa Butcher
  • High Desert Flier
« Reply #3 on: August 23, 2014, 04:56:57 PM »
Have built the Mustang and the Zero. Prefer the Zero. However, you may want to consider the P-40. It was designed by Pat Johnston and has a different wing than the others. With some dihedral it may be the best flying one of the lot. 8)
Pete Cunha
Sacramento CA.
AMA 57499
