  • July 17, 2025, 08:58:37 AM
Author Topic: Source for Ball Links and Both R/H and L/H Pushrod Ends  (Read 4088 times)
Online Crist Rigotti
« on: September 03, 2024, 09:05:44 PM »
Where is the place to buy quality ball links and both R/H and L/H push rod ends?
Re: Source for Ball Links and Both R/H and L/H Pushrod Ends
« Reply #1 on: September 03, 2024, 09:54:49 PM »
Bob Hunt recommended these.  I have 10 of then in Endgame IV.  Smoothest link I have ever seen.  Only downside is that they are hare to thread without a tap.
 https://www.f3aunlimited.com/secraft-ball-link-4-40-qty-10
figures, they are out of stock
Try this one:
https://dreamworksrc.com/product/secraft-al-ball-links-4-40-v110-black/#:~:text=SECRAFT%20AL%20Ball%20Links%20#4-40%20%E2%80%93%20V1(10)%20%E2%80%93
As for pushrod ends, I have been using RC Car turnbuckles.  They come in a bunch of lengths.  Some come in sets and you can find some really good ones inside metal tie rod sets.  The machining on them is better than the typical CL ends
« Last Edit: September 03, 2024, 10:22:55 PM by Ken Culbertson »
« Reply #4 on: September 04, 2024, 09:14:16 PM »
I'm really looking for the Left Hand threaded push rod ends.  Where can I get them?
Offline Brent Williams
« Reply #5 on: September 05, 2024, 12:16:56 AM »
Not sure if the central hobbies pushrod ends have L/R threads. https://www.centralhobbies.com/cat4.php?cat=27&subcat=124&sub2cat=123
If a turnbuckle is a workable option, there are many steel and titanium options.
« Last Edit: September 05, 2024, 01:48:41 AM by Brent Williams »
« Reply #6 on: September 05, 2024, 06:36:41 AM »
The first pix show the ones I have found that are similar in weight (slightly heavier) and long enough to thread into a ball link far enough to prevent twisting.  The twist Hex portion is a good fit for the wrench.  This one is #3 metric but I have found that a Ball Link doesn't really care.  The 2nd pix is the DuBro turnbuckle.  I had one bend under pressure and IMHO the tiny hex for adjusting is just too small.  However, shortened they are probably fine.  In either case, a pair of turnbuckles is the exact same thing as a pair of pushrod ends.  Maybe even better since the threaded end inserted into the CF tube has a better grip when epoxied and you can adjust from either end.
Here is the link for the ones I use, $17.65 for 20:
https://www.ebay.com/itm/374807532222?var=643863586231
« Last Edit: September 05, 2024, 12:53:49 PM by Ken Culbertson »
Online Dave Rigotti
« Reply #7 on: September 05, 2024, 07:30:39 AM »
To answer your question, I'm the only source I know of right now for LH ends. How many do you need?
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #8 on: September 05, 2024, 11:54:43 AM »
at least 6.
