  • July 18, 2025, 04:44:27 AM
Author Topic: Source for .60 Size CF Landing Gear  (Read 1444 times)
Offline Don Jenkins
« on: September 19, 2020, 05:44:28 AM »
Does anyone have a good source for .60 size CF landing gear?
Don
Offline Craig Beswick
Re: Source for .60 Size CF Landing Gear
« Reply #1 on: September 19, 2020, 06:53:47 AM »
On ebay. zy-hobby (4803). 70E size.
I am using it in a 60"+ span ship with a Magnum 52 up front.
$29.50AUD, about $21USD. Quality looks good. Took 2 weeks to get to Australia.
Craig
AUS 87123
"The Ninja"
Offline Steve_Pollock
« Reply #2 on: September 19, 2020, 07:55:36 AM »
Check Steve Wilk's Eliminator Prop shop down in the Vendor's Corner section of this web site.  He makes LG in various sizes, as well as props.
« Reply #3 on: September 19, 2020, 02:10:19 PM »
Randy Smith at Aero Products usually has CF LG's for .60-sized stunters.  y1 Steve
Offline Don Jenkins
« Reply #4 on: September 20, 2020, 05:24:21 AM »
Thank you gentlemen for your replies!
Don
« Reply #5 on: September 20, 2020, 10:54:15 AM »
Don
I have gears  for  profile thru 75s
F2B 6075  gear
F2b 4051 gear
F2B Tall swept
Cf Profile gears
Offline Crist Rigotti
« Reply #6 on: September 20, 2020, 08:15:09 PM »
F2B 6075  gear
F2b 4051 gear
F2B Tall swept
Cf Profile gears
Randy,
Where can I get the dimensions for your CF gear?
« Reply #7 on: September 20, 2020, 08:16:57 PM »
Randy,
Send an email  and  I will  send the  gear chart  to you  Randyaero@msn.com  The chart is formatted good in an email
A=fuselage width,  B=track,  C=height (axle to fuselage),  D=width @ top,  E=width @ foot,  F=sweepback.
Product   A   B   C   D   E   F   Leg Shape   Avg Weight
40% Extra (soon)   240    640    310    60    25   na   curve down   585
F3A-2000   166   456   185   39   22   na   curve down   145
F3A-Winged                       due January 09   130
F3A-Electric   120   470   195   38   22   98 back   curve - back   126
F3A-Long   112   485   215   38   22   62 back   straight - back   128
F3A-Wide   110   440   180   42   22   60 back   straight - back   125
F3A-Curved   112   465   168   38   22   90 back   curve - back   121
F3A-Large   102   394   170   42   22   80 back   straight - back   110
F3A-Std   102   401   150   36   22   78 back   straight - back   95
F2B-60   60   295   85   35   22   na   flat plate style   36
F2B-40   57   268   72   31   22   na   flat plate style   30
F2B (cl stunt)   60   305   120   25   11   38 back   straight - back   35
FAI (pylon) carbon   76   250   78   30   17   na   flat plate style   50
QM (pylon) carbon   36   238   45   24   41   na   flat plate style   50
Offline Don Jenkins
« Reply #8 on: September 29, 2020, 04:00:48 AM »
Thanks Randy, I got the landing gear Sunday.  The F2B CL Stunt gear with the 38 degree sweep worked perfectly for my Dreadnought.  I now have two inches of ground clearance for the 13.5 inch CF prop, where I only had 3/8 inch clearance before.  Now I just have to paint the gear and maiden the plane!
Don
