  • June 18, 2025, 12:25:44 PM
Author Topic: Nitrate dope and Lusterkote  (Read 1650 times)
Offline Phil Coopy
« on: August 02, 2006, 10:45:51 PM »
Just found out the hard way that Lusterkote doesn"t stick to nitrate dope without primer. Question does it work with primer? Possibly if I mix in some MEK?
Phil
Offline Leester
Re: Nitrate dope and Lusterkote
« Reply #1 on: August 03, 2006, 01:42:44 AM »
I've used Butyrate without primer and had no problem with Lustrekote. I haven't tryed Nitrate with or without primer.
Leester
ama 830538
Offline Phil Coopy
« Reply #2 on: August 03, 2006, 07:07:25 AM »
Well I'm back to the nitrate coat....the adhesion was so poor that the Lustrekote peeled off like a layer of plastic wrap. Fortunately the only part I painted was the fuse on my Ringmaster (before assembly). The paint job looked great until I pulled off some masking and the color basecoat came with it.  I'm gonna' go conventional and use dope this time.
Phil
Offline RC Storick
« Reply #3 on: August 03, 2006, 07:27:56 AM »
I have stated this a few times. Lacquers are chemical bond and enamels are mechanical bond. You must have a primer between the two. (or a trick)
Offline Charlie Pate
« Reply #4 on: August 04, 2006, 04:56:36 PM »
Where does epoxy fit (what cate ???gory)?
Offline RC Storick
« Reply #5 on: August 04, 2006, 05:11:06 PM »
Epoxies are a chemically activated mechanical bond type paint. Most Epoxies are activated with MEK. The MEK is sometimes hot enough to act as a chemical bond. So you get both property's in one application.
This is one reason I use lacquer thinner in my Urethane applications.
« Reply #6 on: August 04, 2006, 08:21:49 PM »
Thanks for the info. :)
« Reply #7 on: August 08, 2006, 04:29:43 PM »
Lustrekote goes over dope just fine, but you are correct, you cannot dope over Lustrekote, it won't stick and you have a mess.
Sparky knows all the techy info on this one.
