After some unexplained engine speed changes yesterday I decided to have really good clean through. I had already cleaned the tank (or so I thought) before fitting it to the model by half filling with alcohol shaking it and emptying through a filter paper and found nothing of note after several cleanings. I checked the filter in the model and it was clean. However, today after my day out flying yesterday I opened the filter and found a significant number of "things" 2 small insects, 1 ball of solder and a number of unidentified bits. None of these had made it through the filter but after the cleaning I had done I didn't expect anything!! Looking at the actual filter there are some black tiny things too small to work out what they are but they are on the tank side of the filter.
Today I have filled it with methanol plugged it and run a few cycles in my ultrasonic cleaner. I have ultrasonically cleaned the filter assembly and I await the results next time out
Some pictures from my PC microscope(the filter is 1/4" diameter):-
