  • June 20, 2025, 07:39:55 AM
Author Topic: Uniflow tube location  (Read 1382 times)
Offline kevin king
« on: November 30, 2024, 02:32:52 PM »
Can someone please tell me which is the uniflow inlet on this brodak tank? https://brodak.com/a-t-f-wide-wedge-uniflow-fuel-tank-5-oz.html
Offline Ty Marcucci
Re: Uniflow tube location
« Reply #1 on: November 30, 2024, 02:58:20 PM »
The middle one.  The bottom one in the photo is the over flow.
Ty Marcucci
« Reply #2 on: November 30, 2024, 04:34:05 PM »
To confirm, stand the tank up and fill through the pick up tube. Which ever tube leaks first is the uniflow tube.
MM :)
Offline kevin king
« Reply #3 on: November 30, 2024, 04:54:25 PM »
Thanks guys  H^^
Offline Jim Svitko
« Reply #4 on: November 30, 2024, 07:04:21 PM »
The uniflow line is normally bent inside the tank and the aft end of it should be soldered to the pick up line, just a bit in front of the pick up line aft end.  So, if you slide a wire (i.e. 1/16 music wire) into the uniflow line, it will meet resistance in the tube due to the bends.
For the tank shown, the uniflow line is the middle one, as already stated.
Offline Colin McRae
  • Are we having fun yet??
« Reply #5 on: November 30, 2024, 07:35:50 PM »
Here are the tubing arrangements for all of the different Brodak tanks they sell.
(Also, when Brodak uses the term 'fill tube' in some cases, it is also the uniflow tube on uniflow tanks)
Offline kevin king
« Reply #6 on: December 01, 2024, 02:42:53 AM »
There is one tank set up that is missing from the diagram. The one in the attached pictures. This is the uniflow tank configuration I like and use in my full fuse planes. Seem like it has been discontinued after searching multiple  times of the 35 page tank listings.
Offline Jim Svitko
« Reply #7 on: December 01, 2024, 08:00:18 AM »
If the tank you like is no longer available, then convert the tank that you show in the original post.  Remove that one line (the bottom line as shown in that photo), solder a patch over the hole.  Punch a hole in the tank, where you want that third line to be (as shown in the photo of your last post), and solder another one in.
I have had to do this often on my full fuselage planes.
Offline Jim Svitko
« Reply #8 on: December 01, 2024, 08:08:53 AM »
A word of caution regarding these metal tanks--Since GRW is no longer making them, I have no idea who is making them now.  When I used GRW tanks, I never had a problem.  Now, with a different manufacturer, I have had issues with clogged tanks.
I think the manufacturer is using corrosive flux.  I had engine run problems and could not find anything wrong with the engine, filter, etc. so I decided to remove the back plate of the tank.  The entire inside of the tank was corroded.  The pick up line was clogged with corrosion debris.  A few months later, I had the same problem with another tank.  They were both so badly corroded inside that it was not worth trying to clean them up and put back into service.
So, if you use one of these tanks, and start having engine problems, check the tank for clogs due to corrosion.  It took a while for the corrosion to accumulate so at first you might think all is OK.  A few months later, or maybe even a year later, problems show up.
« Reply #9 on: December 01, 2024, 10:39:04 AM »
       I have seen what Jim describes in many of these tanks. What I think the problem is, is the way they produce these. Flux is flux, and it's all corrosive, that's how it does it's job. It's an acid that cleans metal surfaces. I personally prefer Ruby Fluid flux. It just works better. most people use way too much, but if the joints fit properly, it's like Brylcreem, a little dab will do ya! Heat and capillary action will cause it to flow along the seam, and very little to none should get inside the tank. After water testing for leaks, you can flush the tank out with a little soapy water to flush any flux, then some alcohol or fuel to displace and absorb any water. With the manufacturer of these store bought tanks, I think the way they go about it is the issue. First, they form and assemble the main body of the tank with all tubes, and it's soldered. Then, I think they just dip the ends into a tub of flux and put on the end caps and solder those in place. They simply wipe off the outside with a rag, and don't flush the tanks at all. in a matter of days, the flux will start eating away at any scratched in the tin coating and attacking the steel underneath. Then the stalagmites of rust start forming. I have seen these tanks, brand new out f the package, have a rattle like there was something inside. Remove the rear end cap and the inside of the tank looked like a cave! I advise anyone that when you buy a new store bought tank  of recent manufacture, tap the tank on a soft piece of wood a bit to see if there is anything growing inside that will break loose. If you hear something rattling, just send it back immediately without even opening the bag. They can't argue that the tank was tampered with that way. The people that make these tanks, hire unskilled people at minimum wage to assemble and solder these, I believe. I have seen this before from other manufacturers. Turn over rate is high and it's a constant struggle to achieve any consistent quality. It's the main reason I make a lot of my own tanks. I have a big collection of older, store bought tanks that I can modify with however I want the tube arrangement to be also and I copy some of these shapes and designs if I like how they work. A lot of these store bought tanks have issues with how and where the tubes are secured also, and I have even seen it in old Perfect tanks. I have had to fix and modify a lot of those also.
   As far as uniflow location, the British and Europeans have been using uniflow long before it was discovered here. I have made tanks with the uniflow tube all over the place, as long as it's along the most outboard wall or corner of the tank, and they have worked like they should. I have seen old British plans that show the uniflow tube end all the way at the front of the tank. If you do not understand what someone is describing or referring to about how to plumb a tank, simply make one up and see how it works. With the plastic tanks available, it's quite easy and basic configurations of the tubes can cross over from plastic to metal tanks also. I use about half metal tanks and half plastic tanks, depending on the airplane and what I have at hand and the type of tank really doesn't matter. The only think I avoid is a wide wedge with the pick up tube all the way out at the furthest outboard part of the tank. Centrifugal force works against the fuel as it tries to get to the spray bar and will lean out an engine run once the airplane is airborne and up to speed. Speed flyers use the shimming of tanks for profile speed models outward to hel tune the needle setting and engine run. You can't fight physics, but you can work with it and use it when needed.
   I hope everyone had a nice Thanksgiving!!
« Reply #10 on: December 01, 2024, 11:16:21 AM »
There are three major things that will cause corrosion in the tank :
1. The material used for the tubing.  It needs to be copper.  Brass will corrode very quickly in methanol and nitro.
2. Acid core soldering flux.  Don't use it.  Electrical solder works perfectly well for our purpose and had no such flux.  It is PLENTY strong enough.
3.  Residual moisture in the tank left long term.   If you store you airplanes or tanks where there is high humidity or especially an indoor humidifier you may have trouble.  Likewise for your engines in general.   It will help to plug ALL the vents when not in use.  Windy used to store his with full fuel tanks to block it.  Keep your engines well lubed and turn them over occasionally.
« Reply #11 on: December 01, 2024, 11:46:04 AM »
Old tanks.  These are a collection from old airplanes that I’ve built over the years.  All are usable with no corrosion.  Again electrical solder.  None ever leaked.
Offline Jim Svitko
« Reply #12 on: December 01, 2024, 12:18:33 PM »
I use electrical solder and Nokorode flux.  Yes, all fluxes are corrosive to some degree, but the Nokorode looks to be the least corrosive.
« Reply #13 on: December 01, 2024, 12:49:13 PM »
Jim I use NO FLUX at all other than the rosin within the electrical solder itself.  It's not needed.
« Reply #14 on: December 02, 2024, 06:41:28 AM »
When I attend Brodaks Fly-In I always visit their Hobby Shop for re-supply.  One year I noticed a number of their tanks that were already rusty sitting in their plastic bags.  Yikes!
Online John Rist
« Reply #15 on: December 02, 2024, 06:59:36 AM »
Use plastic tanks converted to uniflow.
