Need a little input.
Was flying my Akrobat today and it seems like it is going to be a good flyer. I was just flying and doing insides and outsides getting a feel for the plane. I hope I am explaining this right. When the plane comes around on the down side of the outside loop it seem to get a little light on the lines. I had my flying buddy look at the flaps and checked the wing, tail to see if anything needing tweaking. Could not see anything, so I thought I would ask here if anyone might have some ideas.
Paul –
Since you did a visual alignment check and didn’t see anything, this probably isn’t it. However, a
high inboard stab tip can cause the problem you describe.
Here’s the deal. A high inboard stab tip, given some down elevator, will cause the empennage lift vector to point the nose towards the center of the circle. Unfortunately, the GP forces are also pushing the nose inboard at the same time, a bad combination.
In effect, a high inboard stab tip works like a
“Rabe Rudder” hooked up backwards.
That is different than saying a low inboard stab tip works like a Rabe Rudder. Stab tilt in the other direction would act like a Rabe Rudder with a maladjusted linkage that gave left rudder on insides.
Larry Fulwider
