You can ruin any airplane by flying in the rain, the lines collect water as you fly, centrifugal force slides the water down the lines and into the leadout guide, it is now in the wing, and migrates from the tip all the way across to the outer wingtip.
We had to fly in water during a NATs and TTs a few years ago, Bill Rich had taken out tip weight and when he removed the box cover a lot of water ran out of that part of the wing. Most everyplane was dropping the outboard tip from all the water inside. The planes can and do pickup over 5 to 10 ounces from inside water.
This is not even to mention the water sticking on the outside and the water that creeps into the hinges and horn areas. All in all try to stay away from flying in rain if possible. I have also seen bad warps starting on older stable planes after rain flying
