How well does the rest of the electronics hold up, like battery and ESC/timer?
John,
If it is a good ol smack the battery will probably have to be neutralized. The ESC and timers are fairly robust.
I still do not see the advantage over IC for a beginner. I've yet to trash an IC motor in a crash, (whittled down for sure) I guess it does happen. But a slight dork with that thin electric shaft and its done.
A new Cox 049 is still 40 bucks, a starting batt and fuel is probably another 20 bucks. Our local racing guru Dave Hull keeps an 049 trainer with him when he is at the field. If anybody comes over to see the Stunt or race planes he offers to let them fly his trainer. It is always a big hit with the kids.
A good electric motor is $15 , ESC is $10 to 30, a timer is $15 plus a programmer at $75, batteries $10 each, Connector bullets $10. You will need a lipo charger/balancer $40 to 100. Even if you get a simple timer a basic electric setup can cost from $100 to 200. Then you need a soldering iron, shrink tubing etc. That said, the Ringrat looks promising. A pre packaged electric and a fistful of batteries , might do the trick.
If our beginner likes flying, that starter plane will quickly be set aside for a Ringmaster or Pathfinder. Of course, the entire power train, motor esc and batteries have to be upgraded just like the IC. The cost for these components are more than an LA 25 or 46.
I currently have an electric setup in my Noblarf and love it. It is my weekly trainer and keep it in the car in case I get out of work with time enough to fly. I can set it up to fly in 2 minutes flat. It always starts and runs the same. It takes another 2 minutes to put it away.
I'd rather fly my 4 stroke Pathfinder or EVO36 Vector, but the time it takes to setup, fuel up, start it, clean it up and put away is too much for my limited time.
But, whatever works is great as long as new folks (or our R/C brethren) take up C/L
