  • July 18, 2025, 07:36:07 AM
Author Topic: uniflow tank  (Read 6140 times)
Offline Steve Hines
uniflow tank
« on: October 30, 2010, 03:41:15 PM »
I pick up a brodak BH-546 wide wedge tank witch line is what. Think the bottom one is the overflow, but after fueling this will let all the fuel run out if I dont cap it. Wished brodak would have labled it. I have never used a uniflow tank. Thanks Steve
Offline jim ivey
Re: uniflow tank
« Reply #1 on: October 30, 2010, 06:34:57 PM »
the bottom line Shoud be the overflow(it goes to the top ofthe tank on the inside). You only need to plug it if you use a pressurized system. however it may syphon from one or both lines when the engine is running. you can stop this by cutting an inch long piece of neoprene tubing and cutting it  approximatly @ a 60 degree angle in the middle leaving 2 pieces app. 1/2 inch long. Put them on the fillerlines angles exposed, one on each side and face the angle toward the prop.  you can adjust the syphon out while the engine is running by rotating slightly left or right till the syphon stops if there is any. make sure the wedge of the tank  is on center with the engine if its a side mount, or on center with the needle valve if its upright or inverted.. jim
Offline Jim Thomerson
Re: uniflow tank
« Reply #2 on: October 30, 2010, 09:06:22 PM »
If the overflow is not capped after filling, you do not have a uniflow tank  I've never flown a commercial uniflow tank, so I don't know what to tell you about yours other than that.
Offline jim ivey
Re: uniflow tank
« Reply #3 on: October 31, 2010, 12:13:25 AM »
Offline Steve Hines
Re: uniflow tank
« Reply #4 on: October 31, 2010, 01:17:18 AM »
Would the one on top pointing forword be the univent and the one pointing forward in the V be the pick-up
Thanks steve
Offline Dick Pacini
Re: uniflow tank
« Reply #5 on: October 31, 2010, 01:56:19 AM »
The overflow comes straight out the bottom.  The uniflow vent comes out of the top and faces forward.  The pickup tube comes out of the V.
http://www.brodak.com/shop_productdetail.php?ProductID=6390
AMA 62221
Re: uniflow tank
« Reply #6 on: October 31, 2010, 06:56:11 AM »
To repeat, If you do not plug the overflow, you have an open vented tank, not a uniflow.   You can run muffler pressure to the uniflow, or not, as you prefer.  Incidentally, I fill through the uniflow line.
« Last Edit: October 31, 2010, 10:48:23 AM by Jim Thomerson »
Re: uniflow tank
« Reply #7 on: October 31, 2010, 02:51:35 PM »
To back this up:
The function of a uniflow tank is to provide an engine run whose pressure at the needle valve (and hence fuel flow) is not a function of the level of fuel in the tank (although it is still a function of the attitude of the airplane).  The way this is done is to make a tank arrangement where there is only one functioning vent, and this vent is submerged in the fuel for most of the engine run.  Because the vent is submerged, and is very close to the fuel pick-up, the pressure at the fuel pick up is essentially atmospheric pressure.  You only want the vent to surface when you have one or two laps of fuel left, so that the engine will lean out to give you warning of the end of the flight.
Contrast this with an open vented tank.  In that tank, the pressure at the fuel pick up is atmospheric pressure plus the head from the weight of fuel above the pick up.  This means that as your engine runs it leans out -- and because our "stunt runs" depend so much on the fuel mixture to regulate the engine speed the engine run will undergo considerable variation from the start of the flight to the end.
If you don't block the overflow tube in your uniflow tank, you then have what is known as a "uniflow tank with an air leak", which, as Jim T. points out, acts just like an open vented tank.  You'll find that -- depending on your engine set up -- if you get the mixture right at the beginning of the run it'll be too lean at the end (if it gets that far).  If you get the mixture right at the end of the run, you'll have to make it too rich (perhaps blubbery rich, depending on your engine) at the start.  I even had this experience recently, with a plastic tank that I made up from some really old parts, including a rubber plug that had apparently passed it's "sell by" date while still in the bag.  Once I figured out that the plug was leaking, the odd engine run problem became clear.
Note: You can adjust planes to fly just fine on open vented tanks, as long as you aren't trying for a "stunt run".  In that case you adjust the needle valve for a run that's close to the fastest that you can get, only a bit richer, and you don't get the engine speed regulation that you would with a "stunt run".
Offline Steve Hines
Re: uniflow tank
« Reply #8 on: November 01, 2010, 05:48:46 AM »
thanks for all the the help, I got the engine to run on the ground. Next is to try to fly it. This is what happenes when you are old and try something new.
Thanks guys Steve
