  • July 04, 2025, 06:32:27 AM
Author Topic: Need some quick measurements for a friend.  (Read 2130 times)
Offline Ty Marcucci
« on: March 03, 2008, 10:22:35 PM »
 some standard measurements off a TEOSAWKI.  Span, chords, area, moment arms, stab width and chords, etc.
« Last Edit: October 30, 2019, 06:12:10 PM by Ty Marcucci »
Ty Marcucci
Offline Larry Price
Re: Need some quick measurements for a friend.
« Reply #1 on: March 04, 2008, 09:14:43 PM »
I found this.....
Here is a little info from Clayton Smith on his TEOSAWKI.
TEOSAWKI
The End Of Stunt As We’ve Known It
Design By Clayton Smith
TEOSAWKI is a simple durable low cost model using readily available .40 to .46 engines that, when measured by flying performance, can carry the CL stunt newcomer from beginner to a 500 point advanced pattern. This one really flies like a “prostunter,” maybe better. TEOSAWKI is a tool to confidently perfect needed skills without the burden of trying to carry, at the same time, the marginal performance of the newcomer’s typical precision stunt models with their seemingly endless tradition of complications. The prototypes have won and placed competitively at contests including Brodaks, King Orange and the AMA Nationals. Even while giving up all builder of model appearance points in expert it has garnered competitive 500+ scores.
Construction will seem unorthodox to veteran stunt builders. The methods are those perfected over the past decade by the Eastern European and Russian combat designers. Even at only 35 ounces ready to fly and 635 sq. inches of wing its durability belies its combat heritage. Crashes into pavement hard enough to break off engine mounts hasn’t stopped TEOSAWKI from flying the same day.
You will find that the TEOSAWKI executes the Precision Aerobatics Pattern easily and at your will. Don’t get distracted by how it looks or its seemingly unusual flapless design. Just get it in the air. Perfect your skills with TEOSAWKI, “show and shine models” will come later.
Specifications:
Span: 53”
Length: 41”
Area: 635 sq. inches.
Root Chord: 14” 13.5% airfoil.
Tip Chord: 10” 12.5% airfoil.
Mean 25% Aerodynamic Chord: 0 degrees sweep. ¾” behind CG.
Step down elevator/stabilizer.
Weight: Approx. 24 oz excluding engine and fuel tank.
Here’s something to get the Prostunt guys really going. TEOSAWKI is asymmetric. Having one wing longer, asymmetry, is not all that unusual especially with older designs. Kind of out of favor today however. But those asymmetric designs and even new ones today have a longer inboard wing. Now the surprise. TEOSAWKI has a longer outboard wing. Not by much, just a quarter inch. Just enough to assure the separation between thrust line and the mean aerodynamic center(MAC). Phil Cartier wrote the best explanation of this in the June 2000 issue of Flying Models. Bill Netzeband had a good comparative test some time ago in Stunt News. What this really amounts to is to place the engine bearer side of the motor mount in alignment with the centerline of the wing. This differs from the typical profile model which has the center of the fuselage instead of the center of thrust bisecting the wingspan. That conventional design results in the thrust line being outside the wing’s physical centerline and closer to the MAC. Because a CL model is flying in a circle the wing’s center of lift is outside the physical plan form centerline of the wing. At the slow speeds of Stunt models this distance between centerline of thrust and MAC is small making its relationship sensitive for good line tension. The closer the thrust line is to the MAC the poorer the line tension. On the TEOSAWKI we are talking about just an extra quarter of an inch to assure that separation. Get the thrust line outside the MAC and you’ve got a freeflight with lines attached. Sort of like an All American Sr. taking off. (You have to fly an All American to understand.) But then why not put the engine thrust line on the inboard wingtip, plenty of separation. A couple pounds of outboard tip weight too, thats’s why. Enough theory for now.
FLYING
Strongly recommend a stock OS 46LA running the stock muffler (the muffler baffle may be removed. Fly on 60 to 65 foot .015 or .018 lines. Prop sizes of 10/5, 10/6, 11/4.5, 11/5, 11/6, and 12/4.25 have worked well. TEOSAWKI’s have proven easy to fly forgiving planes. Good in wind. Good tension everywhere with equal turn qualities. Can turn on a dime if needed. Capable of full pattern even with laps over 6 seconds. Ideal at 5 to 5.5 second laps.
Now fly it. You’ll discover hidden in the TEOSAWKI a character that you’ll know is special. It is The End Of Stunt As We’ve Known It, TEOSAWKI.
Wayne Foster
AMA 959
Winston-Salem, NC
Larry Price
Edgewood, WA
Offline Ralph Wenzel (d)
« Reply #2 on: March 05, 2008, 04:34:10 AM »
And just how does one go about acquiring one of these mythical beasties ? ? ?
Ralph Wenzel
AMA 495785 League City, TX
« Reply #3 on: March 05, 2008, 07:53:09 AM »
Available only from Clayton Smith................  he has about a 6 month back order I understand.
Only available as a RTF minus engine, tank....... (or a really advanced, completed, ARF, if that sounds better! LOL!! )
Offline Charlie Pate
« Reply #4 on: March 05, 2008, 09:57:48 AM »
HI Guys. I need some standard measurements off a TEOSAWKI.  Span, chords, area, moment arms, stab width and chords, etc.  Mine ended up in the trash after a really bad crash. It was beyond any real repairs. Thanks in  advance. H^^ H^^
Ty
I think Marshall Busby has all dimensions and plans he drew up for a T---------
 You might try to contact him. %^@
Offline Michael Boucher
« Reply #5 on: March 06, 2008, 06:20:10 AM »
Anyone has a picture of this one?
AMA 59633
Offline Ray
« Reply #6 on: March 06, 2008, 11:03:42 AM »
Google found several photos when I used that search engine, but right here on this site there are several right here:
http://stunthanger.com/smf/index.php?topic=8432.0
Offline strangepork
« Reply #7 on: March 06, 2008, 12:03:19 PM »
Does any one have any contact details for Clayton smith??
Mick Ives
Alan Hahn
« Reply #8 on: March 06, 2008, 12:11:31 PM »
Ahhhh, it is hard to get.......must have one...........
Offline Wayne Foster
« Reply #9 on: March 06, 2008, 01:49:12 PM »
Since Mr. Smith has gone into the Witness Protection Program, it's very hard to contact him.  Only myself and Bill Little know his true identity.  Ty Marcucci thinks he knows Mr. Smith, but that was an actor filling in for him.
There is a rumor going around that we may see some new and more "Stunt Like" airplanes from the TEOSAWKI line in the near future.  If so, they will be presented here first.  This would be a first step in trying to get Mr. Little to use some term other than "Ugly as Sin" to describe the appearance of the World Famous TEOSAWKI.
See a peak of things to come.
Wayne
Wayne Foster
    AMA 959
« Reply #10 on: March 06, 2008, 04:48:45 PM »
Hi Wayne,
It isn't fair to show Tommy Luper's TEOSAWKI as a legitimate representation. LL~ LL~ LL~ LL~ LL~
Yes, in stock form, the plane is ugly as far as STUNT PLANES go.  But it's performance is not to be denied!
And it's, "Ugly as HOME MADE SIN!"  (get it right! LL~ LL~)
(you *could* very well see me with one very soon! complete with LA 46)
