That's typical "full up and hang on" results! Apply half as much up and allow the top of the loop to go way beyond any 45 degree elevation so you don't bleed off all the speed in that stall-turn attitude you end up flying in. Or else reduce the elevator throw to only 15-20 degrees (between a quarter and 3/8").
With my first FS, I never noticed issues with oblong/stalled loops .... but with FS#2, maybe I am causing this to happen by too much elevator input at the beginning of the loop. I'll try not being so aggressive, and see what happens.
A 9-6 on an LA 25 may reduce the Streak's maneuverability, instead. I like 9-4s on OS 25 FPs, but those are way too fast for a Streak with any more pitch than 4". You may find that a 10-4 and a faster rpm will suit you far better than a 9-6.
FS#1 was way too fast with a 9x6 .... I slowed it down by running a 9x4, and it was still mid-4 second laps. With FS #2, I am running a 9x5 and (mentally counting off in my head) its running close to 5-sec laps. It feels slow and sluggish at 5-seconds, but I think it was helping to give me time to get through some manuevers. Still, I'd like to see mid-upper 4's again. It had a better pull and seemed more solidly flying.
*** I think the reason for slow and sluggish is because of the weight I've added. Remember, the entire nose has been reinforced, and I also had to do some work to the tail section.
Based on what I found with the 9x6 on FS#1, I was gonna try it (and still will), but it hadn't occured to me to try a 9x4 and bump the RPM.
Unless you plan to enter Speed Limit combat events, the only engine "bigger" than a 25 to put on a Streak is the old Fox 35 stunt, and that vibrates a helluva lot more than any ARF nose can handle!
I think you misunderstood me ..... when I spoke of the new Evolution 36 coming it, its definately NOT for the Flite Streak!
Because of all the issues I've had with FS#1 and #2 ARF's, I want to BUILD my next plane from a KIT, and the Evo36 will go in that.
Thanks for your insights! I got lots to work on (flying and trimming) and if I can keep it in one piece, its all good! One lil' mistake and it seems to cost me 2-3 days in repair time. Gettin' sick of that ...!!
FlySafe! Larry (Larrys4227)
