  • June 18, 2025, 03:29:53 AM
Author Topic: how to  (Read 926 times)
Offline Bootlegger
how to
« on: August 30, 2020, 12:05:37 PM »
  Al right class todays test is how to remove the carb body from a Cox T D engine, need all the details, and I'll be obliged.. H^^    D>K
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bootlegger
Re: how to
« Reply #1 on: August 30, 2020, 12:44:40 PM »
 Class you all passed, got it!!! H^^     y1
Gil Causey
AMA# 6964
Re: how to
« Reply #2 on: August 31, 2020, 04:43:41 PM »
Take the prop off! Use the wrench to unscrew the shiny aluminum nut thingy behind the prop driver. Removes the prop driver and unfastens the plastic carb body at the same time.
The wrench also will loosen the venturi to remove the NV assembly from the plastic carb body, if you didn't already do that by the crash method. And it will remove the glowhead and cylinder from the crankcase. For the last operation, I'd suggest heating the crankcase with a heat gun or oven to prevent the need for excessive force...which will/can fubar the cylinder. Remove the plastic carb body before trying to remove the cylinder....but better yet, don't remove the cylinder unless you absolutely gotta.  D>K Steve
« Last Edit: September 07, 2020, 04:05:05 PM by Steve Helmick »
Offline Bootlegger
Re: how to
« Reply #3 on: August 31, 2020, 06:29:24 PM »
   Thank all of y'all got it taken care of...    H^^            H^^
Gil Causey
AMA# 6964
