Hello all
I'm about to start spraying some color on my vector and i was wondering is there an inexpensive paint stand out there?
thanks
Steve,
To answer your question, yes there is an inexpensive paint stand out there. Actually, it's not 'out there', but rather it is something that is very simple to make yourself. There is nothing complicated about making a paint stand....you can fabricate one for youself with items you have around the shop, and maybe a trip to "Home Depot" for some odds and ends.
You can design the stand to meet all of the requirement that you have, including the ability to disassemble it for storage. You can see in the photo, that my stand only has two major parts, and if designed differently, those could be separated for storage.
This stand I put together several years ago, just using materials that I had around the shop. For a stable base, I found an old, very sturdy four-wheel dolly that I had build to hold auto engines. At the time, I was not concerned about the wheels....I only wanted something substantial to hold the planes. But, the wheels turned out to be one of the best features of the paint stand.
Measure for the longest wing you might want to paint, and adjust the length of your vertical support accordingly. In my case, I permanently bolted the vertical support to the base as I had no storage problems. For your application, you could make a "socket" type fixture that the vertical support would plug into.
I don't have a good photo to show it, but the horizontal part holding the nose of the plane, is simple a pipe flange, about 4" in diameter, with the appropriate size piece of pipe threaded into it. Down the center of the pipe is a piece of 1/2" aluminum rod to which the motor mount plates are bolted. This rod is what allows the horizontal rotation.
What doesn't show, is that the length of 1/2" aluminum rod is 'trapped' inside the pipe flange with a large washer bolted onto the end of the pipe. And a small piece of 1/4" rod is used as a handle for rotating the plane. You can get clever and come up with any arrangement for the horizontal rod.
Now, back to the wheels. It was just a stoke of luck that I selected the four-wheel dolly for the base. As it turned out, being able to move the paint stand around was stoke of genius (if I had thought of it, which I hadn't). I do the final masking and solvent cleaning in my workshop, and when done, I roll the stand and plane out into the garage to spray. When finished, I will roll the stand and plane back into the furnace room to "cure" for a couple of days....then roll it back into the shop, and continue with the never ending masking.
Even during the spraying process, it is extremely convenient to be able to adjust the position of the plane without changing where I'm stand relative to the lighting. I frequently spray with one hand, and adjust the position of the plane with the other. It's a little had to describe, but if you used a "mobile" stand, you would be convinced of the practicality of having it mounted on wheels. This allows full 360 degree rotation about both the horizontal and vertical axes.
Incidental, I've seen the four-wheel dollies advertised at Harbor Freight for less than $20. Bottom line, I would find it hard to spray with a stand fixed in one position.
You will gain ideas on how to build your stand as you look at the various items that are for sale in places like Home Depot. .
So hop to it...turn your creativity loose...build a stand that you will love to use, and post a photo of it when you are done.
Cheers.
Warren Wagner
