Gotta put my R/C and Free Flight hats on. Mulvihill Rubber is the free flight event that is traditionally flown at dawn, I believe. I think it's usually one flight, best time wins. Models are usually HUGE with LOOOnnnnggg fuselages to hold long rubber motors.It has always been a popular event and goes back to the 30's if I remember correctly. I think the name may have been changed to Unlimited Rubber along the line.
I used to compete heavily in R/C soaring, and Unlimited is/was a class with no wing span, function or weight requirememnts. During the second ever Electric World Champs held in the St. Louis area in 1988, there was a provisional event call Dawn to Dusk, where teams of 4 or 5 models each had to keep a model in flight continuously from sun up to sun down. A replacement model had to be airborn before the previous team model touched down or you were eliminated. If a model broke up in flight, you had until the last piece hit the ground, and that did happen during the event. This is much more difficult than it sounds and was quite a challenge, and does require a special, purpose built airplane for best results. I think models were limited to 7 cell battery packs at the time, and that requirement dictated the size and weight of the airplane. Not sure if this is still flown anywhere.
