  • June 14, 2025, 11:00:45 PM
Author Topic: Holes in Brodak ribs?  (Read 2690 times)
Online Paul Taylor
« on: April 28, 2025, 02:48:23 PM »
Anyone know what size the holes are in the ribs of Brodak ribs for the rods?
Offline Colin McRae
  • Are we having fun yet??
Re: Holes in Brodak ribs?
« Reply #1 on: April 28, 2025, 03:27:44 PM »
Paul, I have and use the Brodak wing jig and the supplied alum rods are 5/16" dia. The holes in the ribs are a very tight fit so also 5/16". I have reamed the holes 'a bit' so the rods slide in a bit easier. I also have some longer 8mm CF tubes that also work well with the Brodak wing jig.
Offline GERALD WIMMER
    • Auckland Free Flight Club
« Reply #2 on: April 29, 2025, 05:02:09 AM »
Hello Note the holes in my Vector kit did not match the positions you would expect for a jig, they were well out of line.
 No jig was mentioned in the instructions so I presume they had some other purpose.
 My son used a jig with 5/16 rods to good effect on his Gypsy wing so I thought I would try with the Vector and found out it would not work.
Regards Gerald
Offline Perry Rose
« Reply #3 on: April 29, 2025, 05:45:22 AM »
I don't like building a wing in two pieces. I use the Adjusto-Jig on everything. I tape the knock outs in place as necessary.
« Reply #4 on: April 29, 2025, 06:31:35 AM »
I assembled the Brodak B-25 with the Brodak jig.  It's the only accurate way to assemble that wing.
Yes, it needs to be done with two sides.
The holes are a bit tight and maybe loosening-up is a good idea, so you can get them out when it's done.
ALL rod jigs operate on the assumption the holes are precise.
I enhanced mine with wheel collars and a tip-up function allow me to access the bottom of the wing.
Offline Ty Marcucci
« Reply #5 on: April 29, 2025, 07:56:06 AM »
The reason they, the rods or arrow shafts don't fit, is they are metric, the holes are SAE.  Guess how I learned this. D>K
Ty Marcucci
Offline Colin McRae
« Reply #6 on: April 29, 2025, 08:17:33 AM »
8mm CF tubes also work well with the Brodak jig.
Offline jerry v
« Reply #7 on: April 29, 2025, 08:38:15 AM »
Fiberglass driveway markers are manageable  substitute too. Wing is Brodak Ringmaster S-1.
Jerry
Variety is the spice of life.
Online Paul Taylor
« Reply #8 on: April 30, 2025, 09:42:16 AM »
I don’t like building in two sections and 5ft rods.
Now to clear a bench. 🤣
« Reply #9 on: April 30, 2025, 05:34:09 PM »
How do you get the ends of the jig parallel?
Offline Leonard Duke
« Reply #10 on: May 01, 2025, 05:47:31 AM »
Sitting a level on the two rods allows you to check that the jig is not building a twisted wing.
« Reply #11 on: May 01, 2025, 07:12:13 AM »
I just use a carpenter's level on each end and square them up with a T-square (the tool, not the airplane).
On the smaller Brodak models, the P-40 in my case, the holes were too big for the ribs, which was a problem.
« Reply #12 on: May 01, 2025, 10:43:20 AM »
   I assume everyone knows the trick about hooking an electric drill to the rod and spinning it slowly as you pull it out so you don't have to force it.
« Reply #13 on: May 01, 2025, 12:51:18 PM »
   Or even just twiddling it between your fingers. If the holes are indeed5/16", (.312" )  8mm rods may be a bit tighter because they are .003" bigger, at .315".  It helps to measure anything that you use, but if it fit's, it fits !! Music wire will be accurate, cold rolled rod may vary. I haven't used or measured much in carbon roods or tubes so not sure what kind of product specs and tolerances they may have, and it may vary from manufacturer to manufacturer.
« Reply #14 on: May 01, 2025, 01:07:22 PM »
I would bet that the tolerance on ANY manufactured rod or tube of any material is more precise than the holes in wood ribs.
And of, course the ribs are easier to adjust.
If I had trouble extracting a fixture rod, I would hesitate to try to extract it with a power drill, for fear of doing some real damage.
Offline Colin McRae
« Reply #15 on: May 01, 2025, 01:29:11 PM »
I have a 7/8/10/12 mm prop reamer.
I use 8mm CF tubes for the Brodak jig and 'gently' ream the rib holes at 8 mm. Tubes slide in nice and easy, and also easy to extract the tubes from the completed wing when the time comes.
« Reply #16 on: May 01, 2025, 07:14:09 PM »
Hello
Before assembling his Gypsy wing my son spayed the alloy rods with silicon before putting the ribs on.
 Seemed to work well when he pulled them out, even though they were tight fit in the ribs.
Regards Gerald
Offline doug coursey
« Reply #17 on: May 02, 2025, 06:32:11 AM »
WAX ON THE RODS WORKS GOOD TOO....
AMA 21449
« Reply #18 on: May 02, 2025, 04:26:50 PM »
I use Teflon spray on the rods. Also use it on controls.  Doesn't clog up like oil.
