  • July 02, 2025, 02:45:12 PM
Author Topic: Miss Poppy  (Read 1542 times)
Online Ty Marcucci
Miss Poppy
« on: January 24, 2008, 11:10:19 AM »
 H^^
« Last Edit: April 24, 2017, 09:02:20 PM by Ty Marcucci »
Ty Marcucci
Re: Miss Poppy
« Reply #1 on: January 24, 2008, 12:41:34 PM »
What is with the sideways posts?
Chris...
Offline Scott Jenkins
Re: Miss Poppy
« Reply #2 on: January 24, 2008, 12:57:40 PM »
Chris,
Just doze off in front of the computer with your head cocked slighty
to the left when you wake up everything will be normal.
Scott
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
Re: Miss Poppy
« Reply #3 on: January 24, 2008, 02:23:23 PM »
Is this better?
