  • July 18, 2025, 04:57:42 PM
Author Topic: Short Kit  (Read 1579 times)
Offline Dick Pacini
Short Kit
« on: January 02, 2010, 09:53:45 PM »
I have seen this mentioned several times, but I am not sure exactly what is included in a short kit.  Could someone enlighten me?
AMA 62221
  • Gravitywell
Re: Short Kit
« Reply #1 on: January 02, 2010, 10:36:04 PM »
Hi there.  Usually a short kit contains all the wood that must be cut, which leaves the builder to supply the sheet goods, etc.  Hope this helps.  Cheers H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline Dennis Moritz
Re: Short Kit
« Reply #2 on: January 02, 2010, 11:34:04 PM »
Very useful idea, I think. Since most of the cut wood can be harder less expensive balsa and frequently the sheet wood in kits is problematic-- too heavy. Of course rock hard ribs that weigh a lot can be an issue. Though, depending on the construction, much of the weight can be cut away. All in all, a short kit can be a cost efficient compromise between a standard kit (pot luck wood) and a high cost contest caliber 2 to 3 hundred dollar alternative. Different laser cutting services (perhaps even Brodak, RSM does definitely) offer short kits or are willing to cut the equivalent of a short kit from CAD (sp?) drawings. I think many of our best builders use, in effect, short kits, since they laser cut different constituent parts, even in original designs.
Offline Leester
Re: Short Kit
« Reply #3 on: January 03, 2010, 06:40:07 AM »
Action Lazer Works in the vendors corner has a listing of short kits. They will also cut what you want from your CAD plans.
Leester
ama 830538
Re: Short Kit
« Reply #4 on: January 03, 2010, 06:47:18 AM »
If were buying kits, I would rather find my own LE, TE, and spars than have them sawed half to fit a small box.
Offline Tom Niebuhr
Re: Short Kit
« Reply #5 on: January 03, 2010, 08:47:28 AM »
My "Short Kits" generally include any parts that require laser accuracy for proper alignments. This would include fuselage sides, ply doublers, ribs,  custom formed landing gear, gear rib doublers, etc. The parts included will vary some from airplane to airplane.
Hope this helps.
Tom Niebuhr
Blue Sky Models
AMA 7544
Re: Short Kit
« Reply #6 on: January 04, 2010, 10:13:01 AM »
Pictures of short kit I got off the UK bay.  Also a pic of my helper at work.
