  • July 04, 2025, 07:14:55 PM
Author Topic: Ooopsie  (Read 1732 times)
Offline James Holford
Ooopsie
« on: September 01, 2017, 10:17:24 AM »
Think I may have screwed myself.
Upon doing my wingtips on my Shark 402. I noticed this is ehats left of my leadouts.
Maybe 2" sticking out the tip. I do not believe this is enough to wrap and have enough pull pull. Seriously contemplating removing the tips and leaving as is just so i dont have to cut into the center sheeting.
I have no problems removing the tips. This plane was more or less just a trainer for me I got stupid cheap.
Lesson learned....
Thoughts?
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Mike Griffin
Re: Ooopsie
« Reply #1 on: September 01, 2017, 10:57:09 AM »
Don't feel alone.  I did this a couple of time until I decided that leadout was not that expensive and learned to leave myself plenty of excess.  I would do exactly what you are thinking about doing before I would tear into the center sheeting.   I built a plane one time and sheeted over the center before I realized I had not put a bellcrank into the stupid wing.  Crap happens.
Matthew Brown
Re: Ooopsie
« Reply #2 on: September 01, 2017, 12:02:08 PM »
Don't know if it's legal, but I'd just cut them shorter and join on another piece mid panel of the wing to extend them.
Matt
Re: Ooopsie
« Reply #3 on: September 01, 2017, 12:35:53 PM »
I have splice lead outs in side the wing with more than enough material to finish the lead out.   Slide some shrink tubing over the splice and make sure it doesn't hang up on a rib.   H^^
Re: Ooopsie
« Reply #4 on: September 01, 2017, 12:38:27 PM »
I already chopped the tips off. Its no big deal. Should fly fine.. just gona look at it like a Skyray
Jamie Holford
Lafayette, La
AMA #1126767
Re: Ooopsie
« Reply #5 on: September 01, 2017, 12:40:49 PM »
Glue the tips back on as you've ruined the looks of the plane. LL~ LL~
Re: Ooopsie
« Reply #6 on: September 01, 2017, 05:14:53 PM »
Change the leadouts at the BC. Maybe you can get enough BC travel to access each end of the BC without tearing up the center sheeting. Then put the tips back on. Square tips (like a Skyray 35) are inefficient and a disgrace to humanity. Hey, shouldn't you be changing chitty diapers about now?  ;) Steve
Re: Ooopsie
« Reply #7 on: September 01, 2017, 05:40:37 PM »
Hahaha
Jamie Holford
Lafayette, La
AMA #1126767
