  • June 16, 2025, 03:34:49 AM
Author Topic: ??? Need suggestions...  (Read 1812 times)
Offline Bootlegger
« on: November 10, 2008, 09:10:41 AM »
  :!    I am looking at building a "stooge" and want to get suggestions for setting one up on my models, profile and full fuse.
  I don't want to hook to the tail wheel as this set up is removeable on all my models. I am looking at going thru the fuse, but am uneasy about a wire flailing about in the area of the stab & elevator that might get caught in same.
  What say ya'll ??? :!
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline RC Storick
Re: ??? Need suggestions...
« Reply #1 on: November 10, 2008, 09:49:20 AM »
I cant post a drawing but I have seen a device that used 2 wooden dowels in front of the stab one on each side of the fuse. Pull the string and then it folded to the ground releasing the plane.
Offline james dean
  • Rebel with a cause AMA 467575
« Reply #2 on: November 10, 2008, 10:03:57 AM »
After looking over several designs for stooges, heres what I consider the lesser of many evils.  I used a steel plate 3/8 thick with a brodak release and a tube covered cable for the restraint. You do not need a machine shop to build this. If you have a drill press and taps you can make this design in your shop. Remember that stooges are inherintly EVIL and can cause trouble no matter what you choose for a design.  This design has caused the least trouble that research could produce and has given me no trouble for either full body or profile planes and has a reasonable reputation with those who have used it.  Good luck. Hope this helps
Offline james dean
« Reply #3 on: November 10, 2008, 10:05:04 AM »
More pics
Offline james dean
« Reply #4 on: November 10, 2008, 10:05:49 AM »
And another.......
« Reply #5 on: January 26, 2009, 08:56:25 PM »
Jim...I used a similar setup for awhile, except that the cable was replaced with a new nylon shoestring. It worked for a few launches, but then jammed in the crack between the end of the elevators and the fillets. As this was at the Arlington site (big, grass), I held onto the handle and walked into the airplane, behind the lines. Scary, but got away with it. Shut the engine down and went home, you betcha!  :X Steve
Offline Russell Shaffer
« Reply #6 on: January 26, 2009, 10:19:59 PM »
I used nylon cord and it also caught in the tail end.  I wasn't as smart as Steve, I had 2 hang ups before I quit using this.
Russell Shaffer
Klamath Falls, Oregon
« Reply #7 on: January 26, 2009, 10:23:15 PM »
The two dowel method was posted by Leonard Neuman on Stuka Stunt.  There were pictures and it works quite well. No trailing wires or strings.
Russell Shaffer
« Reply #8 on: January 27, 2009, 02:52:38 AM »
Windy Urtnowski showed his stooge in one of his videos several years ago.  He used two barn door hinges, two pieces of 1" dowel attached to them (the other end of the hinge is attached to a sheet of plywood, size up to you) with the dowels covered with rubber pipe insulation.  It releases clean and I made one which I used several times.  This does hold the plane by the stab.
Mongo
