  • August 01, 2025, 08:53:37 AM
Author Topic: Sheet Metel for Fuel Tanks  (Read 2507 times)
Offline Bryan Higgins
« on: March 13, 2010, 09:22:14 PM »
Hello Pilots
Can you help me with what thickness does my Roll of Tin have to be
for building Fuel Tanks.    Thank You ???
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
Offline Scott B. Riese
  • Just a student of stunt
Re: Sheet Metel for Fuel Tanks
« Reply #1 on: March 13, 2010, 10:46:02 PM »
Between   .005 and .008
Scott Riese
Portland, Oregon
AMA 528301
Offline ray copeland
« Reply #2 on: March 14, 2010, 10:16:17 AM »
Scott, any preference on brands or where to purchase?
Offline Brian Massey
    • California Car Clubs
« Reply #3 on: March 14, 2010, 11:35:40 AM »
I've never checked the thickness, but I've cut up empty one gallon fuel cans and used that stock. Just make sure it is completely empty and "aired out" before putting grinder to it . . . ask me why.  n~ n~
Brian
AMA 55421
Madera, CA
« Reply #4 on: March 14, 2010, 12:31:50 PM »
McMaster Carr has the sheets and rolls if need.
HOWEVER, for the past few years I just order Tank Kits from Brodak and solder my own. Support the hobby.
Scott Riese
Portland, Oregon
AMA 528301
Offline raglafart
« Reply #5 on: March 15, 2010, 04:55:31 AM »
Try R S components
http://www.alliedelec.com/search/productdetail.aspx?SKU=090SPEC&MPN=KOTZP682444
Macreadys
TINPLATE 500X300X0.2      US $32 for 10 sheets!
It's double the price here in Oz, but it's lovely to use
John Goodwin
AUS 21261
Offline Bruce Reynolds
    • Dayton Buzzin' Buzzards Home
« Reply #6 on: March 15, 2010, 09:22:55 AM »
I ordered .008 x 6 x 12 K&S tin sheets from the local Ace Hardware.
Online Tim Wescott
« Reply #7 on: March 15, 2010, 10:55:08 AM »
But...
Do you want tin (commonly sold as 'tin'), or do you want tinned steel (commonly sold as 'tin').  That 1 gallon fuel can is made of tinned steel, if you can find metal fuel cans any more.  My Perfect brand fuel tanks certainly attract magnets, so they're plated steel.
McMaster sells tin, and I think they mean tin, not tinned steel.  K&S sells tin, but I'm not sure at all whether they mean pure tin or tinned steel, nor, for that matter, do I have any confidence that they know themselves.
Is there any reason not to use brass sheet?
« Reply #8 on: March 15, 2010, 03:17:48 PM »
Fuel cans are a pain because of the paint on one side and the fuel on the other.  Furthermore, they're just about extinct due to plastic jugs.
On the other other hand, one gallon Randolph dope thinner cans are PERFECT.  Clean on both sides and still readily available.
« Reply #9 on: March 15, 2010, 09:04:13 PM »
Thanks Scott & Everyone
I ordered some yesterday.   H^^
Bryan R higgins Jr.
Arvada,Colorado
AMA#885188
Offline Pinecone
« Reply #10 on: March 16, 2010, 02:55:52 PM »
Lots of gallon cans out there.  Acetone and lacquer thinner from Home Depot still comes in cans. :)
Terry Carraway
AMA 47402
« Reply #11 on: March 16, 2010, 05:01:26 PM »
K&S is tinned steel as a magnate will pick up the pieces.  It is also easy to solder. Just wish they had it in bigger sheets.   H^^
« Reply #12 on: March 16, 2010, 07:11:51 PM »
I bought .007" sheet CRES from McM.-Carr. It's 8" x 12"...and I don't recall if it's 304 or 303. Solder with Sta-Brite low temp silver solder. Maybe this weekend, I'll get a round tuit.  LL~ Steve
Offline raglafart
« Reply #13 on: March 17, 2010, 12:08:26 AM »
Okay
Last time I tell everyone about this TIN PLATE, not brass not tin but quality TINPLATE
Same quality as the K&S but comes in sheets  500 mm x 300 mm and .2 mm thick or in imperial units 19.68 inches x 11.8 inches and 0.008" thick
It comes in a pack of 10, yes 10 sheets and is only US $ 32 for the 10 sheets. Or $3.20 per sheet, what are you paying for the K&S sheets?
The quality is so much better than old tins, try it, it's the best.
Here is the link for you guys in the USA ;  http://www.alliedelec.com/search/productdetail.aspx?SKU=090SPEC&MPN=KOTZP682444
Only trying to share what I've found.
Cheers John
John Goodwin
AUS 21261
Offline pipemakermike
« Reply #14 on: March 17, 2010, 05:18:13 AM »
I bought a pack of tinplate from RS and tank making is suddenly a pleasure
Mike Nelson
Offline Allan Perret
  • Proverbs
« Reply #15 on: March 17, 2010, 11:26:55 AM »
Try R S components
Macreadys
R S  components ???
The link goes to Allied Electronics ...
Allan Perret
AMA 302406
Slidell, Louisiana
Offline raglafart
« Reply #16 on: March 17, 2010, 09:39:39 PM »
R S  components ???
I got to this site from a link from R S components web site, I did say here is a link for you guys in the USA, it does go to a page where you can buy 19 x 12 x 0.008" Tinplate for only US $ 31.75 for 10 sheets! ::)
John Goodwin
AUS 21261
