" I been using non-biased hard point mainly for the last couple seasons. How will I know if I don't try it and have it in MY hand awhile? Part of the fun of learning I reckon.
I appreciate everyones opinions and listen to them but I need to feel and see for myself. So by this years flying season's end......I should know what I want to use. But right now....I'm searching and experimenting. Gotta feel it for myself.
Thanks ya'll. "
Hi Shug
You are perfectly welcome to fly whatever you want, but its not about feeling it for yourself...and maybe physics will NOt apply to me, it will and you will have the problems I talked about and more, the "overhang" in that handle is differant up to down, you will have much different pressures on each at times, when the wind loads up the plane, that is why many CRASH using that type of way different bias on the up and down part leg of the handle. At times if you get caught in hard winds you will NOT be able to put enough muscle in the handle to make the ship turn..and even worse than that, the feels will change on up and down, and the change will be NOT the same, it will be different up vs. down, and much harder to turn on the down line, it is NOT a point that it may not effect you.. it will, physics will apply to you also.
just for your info, fly what you please, but i felt you need to know this info, what you do with it is you call, others have experienced exactly what i am talking about, some have crashed airplane.. solely.. because of using that type of handle, and NO other reason.
Good luck my friend
