  • July 10, 2025, 05:58:28 PM
Author Topic: Self Coaching Question..  (Read 5662 times)
« on: November 15, 2010, 01:15:56 PM »
There're usually no stunt flyers around where I normally flys in the weekends, so getting some inputs has been very difficult.   Just wondering if anyone have some good ideas and techniques on self coaching?
Thanks in advance
« Last Edit: November 15, 2010, 06:45:02 PM by Joe Yau »
Offline afml
Re: Self Coaching..
« Reply #1 on: November 15, 2010, 01:23:31 PM »
Hi Joe,
There's nothing like a coach to improve your flying! y1
However, you can help yourself on the BIG mistakes by using several large highway cones OUTSIDE ( %^) the circle to mark intersections and size.
A video camera set back on the upwind side (judges side) when focused to get the entire maneuver captured ,is also a big help.
Even Windy uses this technique at times.
Good luck & "Tight Lines!"
Wes
Wes Eakin
Re: Self Coaching..
« Reply #2 on: November 15, 2010, 02:07:02 PM »
Thanks for the quick reply. H^^
I will give that a try. (using the cone to reference the intersections etc.) I have briefly tried the video camera thing a while back. I think it just need a wider angle lens..    as the H-8, sqr-8 and the OH-8 goes right off the the screen. and moving it further back to capture everything seems too far away. HB~>
Re: Self Coaching Question..
« Reply #3 on: November 15, 2010, 08:33:44 PM »
Joe...I believe you live somewhere fairly close to Conrat, and suggest you ask for his assistance in the coaching dept. He needs some practise, too, and works way too much. Alternately, you might ask Chris or Joan to fly out to Abbotsford and coach you for awhile!
Howard's "thermal pole" setup is a pretty good start for self-coaching, with height crossbar for bottoms, and the vertical crappie rod is useful for marking centerlines or tangent lines.
I have mixed emotions about video taping. Ok on a clear day, but typically not so good on a grey day. The viewing screen on the camera is hopelessly small, but when you have to wait to get it home and plug into your PC, then it's not too relevant...too late to do any corrective action today. Maybe you have a laptop with a huge screen, tho. Then, too, it appears to me that the tricks actually appear different on video than they do to the judges (or coach). I've found that the corners that are "blinding" in person, (i.e., can't see a radius) change into rather large radius on video, and I have no idea why. The one good thing, is you'd have to put the camcorder on a tripod, which is a huge step up from those handheld vids where the camera follows the plane around the sky.   H^^ Steve
« Reply #4 on: November 15, 2010, 09:17:16 PM »
Quote : I have mixed emotions about video taping. Ok on a clear day, but typically not so good on a grey day. The viewing screen on the camera is hopelessly small, but when you have to wait to get it home and plug into your PC, then it's not too relevant...too late to do any corrective action today
What I do , is have a light 32 inch LCD display, an inverter pluged into my car, will film 4 flights, watch back on site in the car. take notes looking for major errors that I can spot in all 4 flights, with a notepad. Then refly. repeat process.
« Reply #5 on: November 16, 2010, 09:31:13 AM »
Hi Steve, no luck with Mike, Chris and a few others in the club.   as I've sent out an email just recently on that and the response was negative.   I find video taping the flights do work quite well..  At the 2008's local stunt contest,  Hube Start video tape my official flight for me.. and from that I could see how well I flew and how much errors I made.  On the perception of the turning radius.. the video clip below (Saturn/Saito .56 at the 2008 stunt contest) was recorded with a 720P video cam on a cloudy day, and the corners on the inside-square came out fairly accurate as to what I remembered.  :)
« Reply #6 on: November 16, 2010, 09:58:02 AM »
That would be ideal (Instant playback of the flights)..  but the problem is I could barely fit a 60" span stunter in my car, I doubt if the 32" LCD screen will fit in there along with all the other stuff..   I would probably have to get a minivan or something similar for that.  y1
« Reply #7 on: November 16, 2010, 10:34:52 PM »
Well, the big screen would be a good solution. I didn't know the big screen would be compatible with a video cam.
Something like a 20" might be ok, tho, and solve the transport problem. You would then need to set up the camera on a tripod exactly opposite the markers for the trick's (Howard's gizmo on center and cones at each end of the 8's?), and ignore the wind.
 Dunno where you're flying, Joe, but the winds up there do seem to be pretty consistent in direction. Ours are lighter, and thus less predictable. A high-zoot digital camera will help a lot, I'm sure. I'm not buying one unless some grandkids appear, and that doesn't seem likely. Meanwhile, I'd suggest getting your passport renewed and come on down to some of the contests. The site at Auburn Airport is quite good, from the standpoint of facilities and pretty smooth air. Good luck and good flying!  HIHI%% Steve
« Reply #8 on: November 18, 2010, 12:44:30 PM »
Most HD video cam (720 or 1080P) has HDMI out, so they will play on pretty much any LCD or LED screens out there including some HD computer monitors.
I'll have to give that a try.  H^^
It still varies.. just the other day. within less then a hour, the wind shifted 180 degrees, and then the top was different from below 45 degree. then it shifted 30-45 degree again to the left.  Its enough to drives you nuts!   HB~>
Online FLOYD CARTER
« Reply #9 on: November 18, 2010, 12:54:40 PM »
Stunt coaching hasn't been very helpful for me.  About the only comments I've gotten are:  "open it up".  or "lower bottoms".  Well, I already knew that.  I know what the maneuvers should look like.  It is only a matter of practice, which can be done very well while flying alone.
« Reply #10 on: November 19, 2010, 07:52:45 PM »
I remember watching a (tall) fella flying in a contest, Advanced PA, it was. His model wouldn't groove at the correct height, upright or inverted. It was diving for the ground in upright level flight (he'd yank it back up about 4-6 times a lap), and flying quite high (10-12') inverted. Having gone through this before, I looked to see his handle in level flight. He was holding considerable "up" upright, and "down" inverted, this with a large homemade handle made from clear Plexiglas or acrylic. I mentioned this observation, but the 2nd round was exactly the same.  Oh, well, I tried. You never know where a useful observation/info will come to you. Pay attention, and think about it, at least!
Recently, well, up until the trip to Clovis, I've been pushing myself to adapt to the new SV-11...that still needs to happen, but our weather here has been pretty miserable. But along the same vein, I haven't really played with the handle much. Bolted on a Ted Handle, guessed at the spacing, eyeballed neutral, and it worked pretty well. I thought. I had a problem with takeoffs being too abrupt...sorta like I practised on grass but was flying on paved. Pete and Mike suggested a neutral adjustment, and I dragged my feet. But I finally did it, and what a difference. Nice takeoffs! I had been thinking that it was due to the engine rpm coming up instantly on release. Not the case...
Then, too, Pete mentioned that maybe a narrower handle spacing would help smooth the corners on the squares and triangles. I still haven't done that, but I will, next time out...first thing. I learned something, flying it on that Dry Lake in Owens Valley (2,500' ASL). Lower bottoms, smoother corners. Basically, I had the handle spacing set for that 2,500', and should have had it smaller here at home and at Clovis. Recently, at home, we were talking about changing the handle settings. I think it was Pete that said to change the handle before the first flight, when you have little or no "muscle memory" to influence your opinion. Also less likely to crash due to changing your response rates.
Ok...there's three examples. I can give more, but won't.  I think it is very difficult for some of us to respond well to coaching. Including me. Thinking back on it, I am sure I have ignored good coaching advise, and quite likely PO'd my buddies by saying the wrong thing. It looks to me like the coach needs to carefully choose his words and draw some pictures, even if it's just with a stick in the sand, or chalk on the asphalt. The coachee needs to nod in agreement or ask some thoughtful questions about how to correct the issue. Don't argue with the coach!  n1 Steve
« Last Edit: November 20, 2010, 09:27:35 PM by Steve Helmick »
« Reply #11 on: November 19, 2010, 08:01:37 PM »
As I learned many years ago flying F2C, "If someone that is better than you or just as good makes a suggestion, try it".  It was the period when Wright & Dunkin were trying to teach me and my pilot.  Wright would say if something worked, use it if it improved your results.  If not go back to what you had and stash away the suggestion as it might work on another plane.  I try my best to use what has been told me in trying to improve in stunt, but just don't fly enough. H^^
« Reply #12 on: November 20, 2010, 10:04:48 PM »
Can anybody post a picture of Howard's Crappie Pole thang? Other, similar devices? Thanks, Steve  #^
« Reply #13 on: November 21, 2010, 10:01:45 AM »
Alan Resinger has one too.   I've tried to order one, but the shipping was like $50  :o and the pole was just $9.99 for the 16.5' one.
« Reply #14 on: November 22, 2010, 09:32:22 PM »
Joe...Oddly enough, I found a fishing tackle shop in Edmonton that had Crappie Poles in stock, for the same price as down here. I don't recall who actually found the poles, but probably Gary Gingrich. Maybe Bruce Perry. Not me, I was probably drooling on the G.Loomis display, or Lowrance depth finders.
Bottom line, I would not be too surprised if you could find one locally for a reasonable price, if you get on the phone. For a long, fragile item like that, shipping will be a killer. We do have a Cabela's store in Lacey (N. Olympia)...right on the way to Chehelis for the RF Stevenson Memorial Raider Roundup, OBTW. Hard to smuggle, tho. Seriously, it might be a problem to get in your car, with the 60" stunter, the 32" HD TV, the video camera, the tripod, the fuel jug, the tool box, the......  LL~ Steve
PS: I'd still like to see a picture of all the PVC pipe support bits that Howard engineered. The crappie pole is easy to visualize, or I could go look at the old fiberglass one I have in the shop...used for many years for thermal detection. Not all that well, I might add. Mylar streamers lie like dogs, as do Hawks and Seagulls. Strange as it seems, Swallows are the birds that are the most reliable thermal detectors I've seen. Prairie grass about 8"-10" high is also pretty infallible.
Offline Jim Thomerson
« Reply #15 on: November 23, 2010, 02:47:49 PM »
If you are self coaching, read and reread the rulebook.  You will find that you forget things, and developed habits you don't want, while thinking you were flying good maneuvers.
Online Howard Rush
« Reply #16 on: November 23, 2010, 03:50:06 PM »
OK, here are some pole pictures.
Online Howard Rush
« Reply #17 on: November 23, 2010, 04:03:06 PM »
The five-foot-high crossbar seems to be useful at judging clinics, but for practice it works mostly as a once-a-lap check on level flight height.  Sometimes I get a glance at it at the bottom of a loop.  A better indicator is the wide yellow thing on the fence tops at Buchanan HS in Clovis.
The wind pole has a 1"-wide Mylar streamer tooted with fluorescent paint, as is the crossbar. I wear orange sunglasses, so I can see them pretty well.
« Reply #18 on: November 23, 2010, 08:23:07 PM »
Why the ginormous rubber band, Howard?  ??? How's the sneaux? Those must be old pix... @@^ Steve
Offline Alan Resinger
« Reply #19 on: November 23, 2010, 09:28:46 PM »
Steve,
I stopped at Cabela's on the way down in September and that store doesn't carry the poles that Howard and I have.  No crappie fishing in the PNW.  They have to be ordered online.  Collapsed they are only about 4 feet long so shipping shouldn't be all that much.  They extend to 16.5 feet.  The shipping figure that Joe quoted obviously was to Canada.
Alan
Online Howard Rush
« Reply #20 on: November 23, 2010, 11:52:52 PM »
I fetch those things when I go past Cabela's HQ on the way to the Nats.  I didn't think the local one would have them, but Steve knows more about fish than I.  I currently have an extry one if anybody needs one.  The wound-up streamer sorta looks like a rubber band.  Is that of what you write?
We only had 3" of snow here, but yesterday was one of those zero-friction days on the local roads.  I might do me some skiing before the rain melts the fun.
« Reply #21 on: November 26, 2010, 11:27:54 AM »
I had the similar comments also.. ("open it up") and I also knew that too.  Infact it was my plane at the time, as it likes to turn smaller inside vs outsides. so on the H-8 I adjust the outside's size to the same as the inside.
« Reply #22 on: November 26, 2010, 12:19:13 PM »
I've also been told to narrow the spacing..    Handle adjustment is something I check routinely nowadays,  and have tried it on all of my stunters. BUt, it didn't all work for me.  Some got terriblily worst! as I couldn't fly the lines of the square-8 as precise.. cause it needs too much wrist movement to turn the corner.  while other planes was better.  The type of coaching I'm interested in is more to do with  "flying techniques"..  to give me a guideline or a check list to what to focus on.   including body posture, handle position,  as to certain way to execute a maneuver..  or like a certain part of the maneuver must be lead through, step forward or back in certain condition, etc.  of course the engine run, and the trim of the stunter should be up to par.   I believe a good coach should also listen to the pilot's feedbacks then suggest constructively  IMO.   H^^
« Reply #23 on: November 26, 2010, 12:31:00 PM »
I guess its worth a try to look around to see if there're any locally..  D>K
« Reply #24 on: November 26, 2010, 12:35:54 PM »
I will certainly do that. H^^  now that there are some changes to the new AMA rules.
« Reply #25 on: November 26, 2010, 12:41:00 PM »
Thanks for posting the crappie pole pics.  Thats quite a set up!  I like the 5' level flight/ bottoms check bar..   H^^
« Reply #26 on: November 26, 2010, 01:35:53 PM »
I would think that is pretty logical.. and I'm all ears when it comes to ways to improve things.   but there are times some suggestion were given from an one dimensional prospect.  For example: if the plane is not quite trimmed, and has bad habit..  How would this person know unless he fly it. y1
« Reply #27 on: November 26, 2010, 07:12:20 PM »
  Having the controls too slow will frequently make it difficult to do the corners without hops. Of course there's a huge continuum of tradeoffs between CG position, control rates, and flap/elevator ratios and there's no reason to imagine that the same fix will apply to different airplanes, or even the same airplane in different conditions or with other changes.
  It takes a lot of experience to know how to even experiment logically, much less know what to do in a given situation. That's the real value of practice, and of having experienced fliers as coaches. Some pilots don't do all that well at it.
   Absolutely. When Ted, David, Phil, Jim, and I are out seriously practicing/testing, we spend the vast majority of our time working on trim and techniques, and not so much on the shapes and errors. We will discuss the shapes but generally in the context of the flying techniques and/or posture/trim/engine issues that might be inducing the shape errors. We tailor it to the individual and different people need to hear different things.
    Note that we have it very good. The fact that we have 5 national-level competitors all collaborating to varying degrees is why a few people think we are cheating. It's not a matter of one ace "holding court" with his followers, we all contribute to our mutual benefit.
« Reply #28 on: November 26, 2010, 10:25:04 PM »
Joe,
One problem that is probably more serious than not having anyone near by to coach you is the very real possibility that your airplane might be more of a problem than your flying skills.  Brett and I (in particular) have tried repeatedly to make the point that airplane and engine trim are about 95% of flying really good patterns.  Pretty much all of us can tell whether or squares are square and our rounds round.  How to get the airplane to fly them so they look right consistently is the secret to doing so.
The subtleties of proper trim are such that, except for the most gross of errors, it is very, very difficult for even a good coach to tell when a problem is pilot related or airplane/engine related.  Telling somebody his corners "suck" is not going to result in a fix unless you  eliminate the possibility of it being just plain impossible to fly the airplane through a decent corner no matter how good a pilot is on the handle.
Brett has been very unselfish over the years allowing decent pilots to fly his Infinities to see how they compare to their own ships (I've flown a lot of Brett's airplanes and they are pretty much point and shoot operations for anybody with a lick of talent).  Almost without exception doing so has been an eye opener for these guys  (Larry Fernandez on the forums has been very open about the impression flying an Infinity had on his ability to evaluate his performance with his own ships...and to recognize when he is beating a dead horse and something needed to be done to the airplane...because it wouldn't ever fly good patterns the way it was).
If a guy flier hasn't routine access to a regular coach it would be worthwhile to enlist the help of the nearest "no kidding" expert, drive to where he is, rent a room, and spend a weekend or two with him fine tuning your equipment until he feels it is competitive.  This means letting him fly and adjust your airplane (with the risks that entails) even if it means a little cutting and pasting.  Listen and take notes when he makes suggestions so you can learn "why" he is making changes.  Make sure the guy is somebody you are willing to listen to and act upon the suggestions he makes.  Nothing is more frustrating for a guy trying to help than to be met with "I don't think I want to do that" comments after spending a good chunk of time evaluating what needs to be done.
I make that suggestion because I truly believe that most people with reasonable physical skills can fly a well trimmed airplane well enough to score 500+ point patterns.  When an airplane turns predictably and flies at the end of the lines at a constant speed it is really only a matter of pointing it where it needs to go.  If the pilot knows what round means and what square means and what equilateral triangles look like flying a well trimmed and powered airplane to trace those shapes isn't rocket science (with apologies to Brett).  If, however, the airplane needs to be hauled around insides yet jumps through outsides and the engine runs six different speeds throughout a square eight even Brett's rocket science honed skills aren't going to fly it well.
Ted Fancher
« Reply #29 on: November 26, 2010, 10:35:01 PM »
 Excellent points and explanation Ted. y1
 Beyond all of that goes the old sayings about finding those better patterns in the bottoms of the fuel jugs. :)
« Reply #30 on: November 27, 2010, 12:14:28 AM »
Roger that, on Ted's and Brett's posts. I have come to have some doubts about that old saying, however. Practising errors can't help. Practising to compensate for an out of trim airplane won't help. You can't trim in turbulent conditions, and I can't see anything to be gained from practising in that stuff, unless you are only trying to get experience flying in those conditions.  Probably not for every skill level, huh? I'm just sayin' that sometimes you can get something from practise, and sometimes you can't, so don't. Some of my more progressive days have been when I was out all day and spent a lot of time in the lawn chair between flights, thinking about trim changes or what I was doing wrong.   %^ Steve
« Reply #31 on: November 27, 2010, 01:38:34 AM »
      I think we pretty much abandoned the underlying idea behind this aphorism quite a while ago. I can't speak for everyone, but I am *very limited* in the number of flights I can fly and stay at peak performance and level of concentration. I have done the best when I flew just enough flights to get familiar with the engine settings in different conditions, flew a decent number of flights, and they laid off for a few weeks before the big contest.
    Just going out and burning in flights is something my buddies and I pretty much *never* do.
Online Howard Rush
« Reply #32 on: November 27, 2010, 02:48:25 AM »
Two people who can tell you what trim change you need just by watching your airplane are Brett Buck and Mike Conner.  Mike lives in your neighborhood.
« Reply #33 on: November 28, 2010, 11:48:24 AM »
Hi Steve,
I'm about 98% in agreement with all of the above.  The only area I would dispute would be the value of flying in bad air (with realistic limits, of course).  I would never suggest doing this routinely but--especially for someone learning the value of proper trim and how to go about achieving it--flying in bad air can go a long ways towards learning the efffects of proper trim.
The single most important thing that can be learned by flying in high winds is how important it is to have the CG in the "right" place.  The question then, of course, is what do I mean by the "right" place.
In stunt heaven air an airplane can be balanced almost anywhere it can fly stably and still be "trimmed" to fly award winning patterns.  (The exception, of course, is that a tail heavy ship will never fly well).  Within reason a straight stunter of reasonable weight that is nose heavy can have control deflection and handle line spacing adjusted so as to allow acceptable cornering.  It won't be technically optimum but, for what we do, such a ship could win a lot of contests with a good pilot at the handle.  The temptation would be to say the CG was "right" because of those trophies.
When flying in the wind, however, such a ship will rapidly travel down the trophy list if competing against good pilots with airplanes trimmed so as to mitigate or largely eliminate the deleterious effects of acceleration in the winds and the effects of the accelerated CG on the ability of the airplane to turn corners with the available control deflection.  If the CG is forward of the location on the wing where lift is "centered" (roughly 25% aft of the leading edge at the average chord)  any increase of speed in a loop or corner of a given radius will increase the "weight" of the airplane (g forces).  Because that increased weight is forward of where the lift is generated it will attempt to "open up" the corner or make the loop "bigger".  (This CG/CL relationship's tendency to "open up" the corner is a form of "negative pitching moment").  As a result the control deflection required to fly those sized loops or corners will be increased.  The pilot will have to substantially modify his/her control inputs compared to what is necessary in good air.  It is "entirely" possible that a ship that flew well in good air will not have enough control deflection to over come the "opening up" tendency in high winds and full control will not provide sufficient pitch rotation to avoid the ground.  That is not good!
A properly designed and trimmed airplane (one that has the CG located at or very near that magic 25% of the average chord location AND that has a large enough tail volume to be stable at that CG location) will suffer only a fraction of the "opening up" tendency of the same ship with a more forward CG (slightly off the subject but of interest; there will be some increased input required because simply flying faster [winding up] means that more lift is required to achieve the desired corner or loop size...thus requiring modestly increased flap deflection which is another source of "negative pitching moment".  The amount required is only a fraction of that required by more forward CGs).
The bottom line is: it is of value for a serious upcoming flier to practice enough in high winds to: A. refine his CG trim, and; B become aware of the ultimate effect of high winds  on the response rate of the ship; C. Learn how to takeoff and land...which is by far the hardest part of flying a well trimmed airplane in high winds.
Having said that, I'm in complete agreement with Steve with regard to practicing in turbulent conditions.  Unlike flying in winds whose effects can be mitigated with proper design and trim because the effects are predictable, turbulence, by definition, is unpredictable and thus can't be mitigated nor can the pilot achieve "knowledge and skills" to prepare for it.  If it is hazardous and unpredictable it makes no sense to risk the airplane unless one of those big plastic bowling trophies is at stake!    ;D ;D ;D ???
Ted
« Reply #34 on: November 28, 2010, 06:37:41 PM »
Ted...Didn't say anything about avoiding flying in wind....just turbulence. Wind, at some flying sites is not a big deal, but at most the ones I go to, it is a very big deal if you want to take your plane home in one piece. I really enjoyed flying on the dry lake in Owens Valley, after Clovis. While there was a fair breeze, it was amazingly smooth. That just doesn't happen at any of the flying sites I habituate.
I don't know about where Joe is flying, other than the Rice Mill Road site, which is pretty turbulent when the wind is from the usual direction (the river & bay). If he's flying out around Abbotsford/Sumas, then it's most always windy (VGMC  had a FF field out at Sumas long ago). Whatever is upwind, I dunno, but a row of Poplars probably won't help.   H^^ Steve
« Reply #35 on: November 28, 2010, 09:01:04 PM »
I totally agree..   H^^
Joe,
Its quite possible, but I can't say all of my planes are that badly out of trim.   I have a Magnum Plus derivative thats built by Keith Varley that flys very well.  Maybe except for the one plane that used to hunt badly on inverted flights..  HB~> H^^
I'm always very interested to see what a well trimmed planes flys like..   some planes surprises me as to how easy it is to fly "consistent & precise" right on the very first flight. :)
Not sure how that works with electrics tho.   LL~ H^^
That is quite true! At the local 09 stunt contest..  Mike Conner was the only one that pointed out that my Saturn was hinging a bit from inside to the outside's transition on the OH-8,  and told me to remove some tip weight.   I've emailed him also.. But he's a busy guy. D>K
« Last Edit: November 29, 2010, 09:53:53 AM by Joe Yau »
« Reply #36 on: November 28, 2010, 09:32:23 PM »
Steve,  I'm currently flying at the Rice Mill Field in Richmond..   and you're right about the turbulences from the wind.  I think the worst condition is when the top is different then 45 degree below.  most noticeble on the hourglas, OH-8 maneuver, and many time resulted free flighted across the field. It was really bad (15-20+km wind with very turbulent air week after week)  a few months before our contest this year.  but I think it is the time of day I usually get to the field. (found out a few months ago) cause there was a few time I arrived right at 9:00am in the morning and it was like stunt heaven. then the wind picks up at 11:00.    There is another flying field out in Coquitlam,  just off Pipeline road. I've only flown there twice this year. Its not bad when there's no wind.  but if the wind comes up, It is usually a swirling wind (from the tree that surrounds the field) which makes the plane skid, and its very unpredictable with directions, as it would keeps changing.  Alan & Keith would not fly at that field.
« Last Edit: November 29, 2010, 09:16:24 AM by Joe Yau »
« Reply #37 on: November 29, 2010, 10:44:01 AM »
Thanks everyone for the replies..  H^^
Lots of great thoughts & idea..   I gather that a good HD video cam on tripod / a 32" LCD screen on inverter, a crappie pole (Howard's set up) with the 5' level flight/bottom reference marker, and a couple of red cone.  then I'm all set!  :)  Oops! forgot about my plane.  :! I guess I need a minvan also.  to fit all this stuff in. Of course nothing beats a good stunt coach ones could work with.. H^^
« Reply #38 on: November 29, 2010, 12:48:22 PM »
Steve,  I reread your post and you're absolutely right.  You mentioned only turbulence--so we agree 100%!!!  Nonetheless, the info on wind and trim are still valid for those who want to wade through it.
Ted
