Usually I avoid making any comments about after run oil because all sorts of stuff gets insisted upon and usually someone gets pissed.
But.....if the discussion goes on long enough.....usually I can't stand it and have to make some comment(s).
I have tried everything including Rislone recommended by GMA.
Rislone discolored the pot metal cases.....didn't do THAT again.
I'm not saying the usual after run oil didn't work....just that there was always some attribute that prevented me from continuous use.
What works for me is.....
Castor.....works but solidifies....naaaa
Refrigerant oil....works but too hard to get.....naaa
Marvel oil....works but stinks.....naaaa
Gun oil....works but stinks....naaaa
LPS....works but stinks....naaaaa
Kroil....works but stinks....naaaa
PB Blaster....this stuff stinks SO bad that the wife will pitch a tent for you in the back yard.
There are a few more I have tried but you get the idea.
What I finally settled on is......Castrol fully synthetic 00-20 motor "oil" available at Walmart.
It works great, available, does not solidify or get gummy, good long term storage oil, good after run oil, does not affect the glow plug because it is a lot like the synthetic oil we all use.....AND...it doesn't stink!!
Even though the engine may have a lot of this oil inside and flooding the plug, the engine starts right up without flushing it out first....it seems to be much like the synth oil used in glow fuel.
I don't think the weight of the Castrol makes much difference but I like to use the thinnest I can find.
I use it after every flying session and haven't had a rusted or corroded engine in years.
Try it!
