  • July 15, 2025, 01:18:18 PM
Author Topic: sealing wood props?  (Read 2412 times)
Offline Gordon Tarbell
sealing wood props?
« on: May 12, 2007, 06:59:58 PM »
After I sand and reshape my wood props what is best to use to reseal them? My old aerogloss fuelproofer is all dried up.
Gordon Tarbell AMA 15019
Offline wmiii
Re: sealing wood props?
« Reply #1 on: May 12, 2007, 07:03:14 PM »
 I just use a couple of coats of clear butyrate, or a coat of sandable epoxy.
 Walter
walter menges
« Reply #2 on: May 12, 2007, 07:16:00 PM »
One of the spray can polyurethanes are fuel proof.  I hope someone can come up with which one it is!  I can't remember right now.........  just another possible alternative.
I have followed Bobby "Champione" Lampione every now and then and finished them up to match the plane with colored dope and clear dope.
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #3 on: May 12, 2007, 07:43:14 PM »
I use Deft spray ploy from Home Depot.. Just check the label and make sure it says something about being  Alcohol safe after drying.
Spray a pretty good coat on both blades, put it on the balancer then spray more on the light blade. Works great to balance a slightly out of balance prop.
« Reply #4 on: May 12, 2007, 08:02:51 PM »
 you can 'feed' the timber with wood oil !
« Reply #5 on: May 12, 2007, 08:26:03 PM »
Is that like tong oil? It does not sound as fuel proof as the Deft stuff mentioned.
« Reply #6 on: May 12, 2007, 09:20:46 PM »
Pretty sure it is the Deft Polyurethane I was thinking of!
Walter Hicks
« Reply #7 on: May 12, 2007, 10:37:32 PM »
I seal with thin CA glue rubbed in with a paper towl.Sand with 400 do this several times. Shoot with Spray can auto
primer . Sand and repeat to the degree you want a good finish shoot with whatever paint you choose then
final coat with clear auto paint as this is very fuelproof .
Offline rob biddle
« Reply #8 on: May 13, 2007, 03:07:43 AM »
  2-pack polyurethane automotive clear works for me.
 Cheers, Rob.
Robert Biddle
Online Chris Brainard
« Reply #9 on: May 13, 2007, 10:35:21 PM »
Clear Lustrekote.
Chris
Offline dave shirley jr
« Reply #10 on: May 13, 2007, 11:23:37 PM »
I shoot them with auto clear But i would say whatever you shoot the airplane with
iunless you use monocote or some such!
dave jr.
« Reply #11 on: May 14, 2007, 07:11:50 AM »
dave jr.
Dave, what "size" Stuntwagon is that one??  Engine?
TIA
Offline Jim Morris
« Reply #12 on: May 14, 2007, 07:42:25 AM »
clear polyurethane wipe on with a paper towel, more or less for balance, but just a real thin layer is plenty.
« Reply #13 on: May 14, 2007, 07:50:40 AM »
Hi Jim,
I was happy to see you Saturday!
Offline Jim Morris
« Reply #14 on: May 14, 2007, 09:55:28 AM »
Thanks Bill, same here, sorry I had to leave early. I heard it was all good. Come and see us anytime.
« Reply #15 on: May 14, 2007, 11:04:38 PM »
hi Bill
its a big stunt wagon OS 61 SF reworked by me. 12/6 hand carved prop
i flew it at tucson
Dave jr.
« Reply #16 on: May 15, 2007, 06:33:01 AM »
Dave does really cool stuff. I saw his planes at Tucson, and they are true craftsmanship. And he's fast too. Right Dave? Dave builds so fast that some of his planes just burn up on the building table. LL~ y1 Your props are beautiful Dave. y1
Offline Al Rabe
« Reply #17 on: May 15, 2007, 07:46:25 AM »
I do a lot of work with wood props, reprofiling, repitching and adjusting undercamber.  I am more interested in getting to the circle to check performance.  I apply a quick finish with medium CA wiped on with a paper towel.  I add extra coats to a single blade to bring the prop into exact balance.  I consider this finish satisfactory for full normal use and life, probably as good or better than the original paint finish.  When I have a very good prop that I'm completely satisfied with, I'll sand the CA down and paint the prop with black epoxy.  Meanwhile, I can go from bare wood to installed, ready to fly, in about 15 minutes.
Al
« Reply #18 on: May 15, 2007, 05:48:06 PM »
Hi jim
thanks for the compliments,i guess i do build pretty quick. it seems pretty normal for me though
Gotta keep the flames under control, that was a little scary. the fire extenguisher is kept a little closser these days.
hey the skin grows right back anyway.
but the tile floor took a little more work
Dave jr.
(hey look out next year, dad has the plans for the icarus and found an anderson for it.)
 f~
