  • July 20, 2025, 12:39:37 PM
Author Topic: Scratched canopy  (Read 2562 times)
Offline steve pagano
Scratched canopy
« on: December 17, 2007, 01:14:28 AM »
Can you sand scratches out of a canopy?
                                T.I.A.
                                      -Steve
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
Offline Jim Oliver
Re: Scratched canopy
« Reply #1 on: December 17, 2007, 06:59:54 AM »
How thick is the material and how deep are the scratches??
I have sanded with 1500/2000 grit then rubbed out with Brasso---results not too bad.  Also, a few coats of clear dope will restore the shine (or melt the canopy, depending on the material).
Jim
Jim Oliver
AMA 18475
« Reply #2 on: December 17, 2007, 07:20:35 AM »
Hi Steve,
Iin the majority of cases, you can sand out the scratches.  You will have to follow the same procedures as you would in rubbing out a finish.  Most all of the canopies now made for our planes are not affected by clear dope, and it is standard procedure to clear right over the canopy in the finishing process.
« Reply #3 on: December 17, 2007, 08:30:41 AM »
Toothpaste will take out a lot of really nasty scratches, but tends to leave a dull finish.  I've used various automotive compounds, cleaners, and plastic polishes with mixed results.  Generally it's easier to prevent scratching a canopy then it is to remove the scratch and return the original appearance.
Offline Leo Mehl
« Reply #4 on: December 17, 2007, 09:33:13 AM »
I think Windy Urtinowski actually sprays clear dope over the canopy as part of the finishing process and rubs it out with Gorums polish. This also helps protect it from scratches. Thanks to him I do the same thing but have been known to scatch them up on outside squares. Usually you can tell because if I start with a round rudder and eventualy it is squared off at the top the canopy has been scratched too an usually a little road rash on the top block. all in a days confussion HB~>
« Reply #5 on: December 17, 2007, 10:14:20 AM »
Uh.....Leo........... uh........... read my reply #2 above........
« Reply #6 on: December 17, 2007, 10:57:18 AM »
I guess it depends how deep the scratch is..  I use Plexiglass polishes like Craftics20/20 or Mequiars Plastx. Craftics has rubbing compound which is great for removing deeper scratches and Meguiars is finer (only good for minor sratches) and give you a shinier finish. I use both in some cases, then finish with a Lucite plexiglass cleaner.
« Reply #7 on: December 17, 2007, 09:00:22 PM »
     The canopy is on a kenhi panther that was given to me my first year of flying. I'm not sure what year it what built in but on the rudder it says kenhi panther 1954. The finnish was aged and dull and I'm looking to refinish it hopefully to look the same way it did when it was first built. It was fitted for a fox 35 but i replaced it with a L.A. 40
P.S. Any one know of a good Ready To Fly weight for this bird?
                                       T.I.A.
                                           -Steve
A.M.A. 820-823
Offline Rudy Taube
  • Ret Flyboy
« Reply #8 on: December 18, 2007, 03:44:12 PM »
Hi Steve,
What Ty said.  y1
But, if you still want to try and restore it you can try this:
http://stunthanger.com/smf/index.php?topic=7598.new;topicseen#new
We used to use a product (I think it was called "Miracle Glaze?) on our FS planes. I think the above product is similar. It is not just a cleaner. It actually fills the scratches and when it drys, it drys perfectly clear and the scratches disappear. You end up with a crystal clear canopy.
If you are really serious about restoring your canopy, you can make a male mold of it and send it to Eric at RMS. He will make a perfect canopy for you.
I still agree with Ty's plan. Our flight lines need more planes with "Character"
Rudy
AMA 1667
« Reply #9 on: December 19, 2007, 09:39:47 AM »
Hi Steve,
What Ty said.  y1
Actually, Bill Sawyer already has canopies for the Panther.  And, they are quite nice, I have one!
« Reply #10 on: December 19, 2007, 09:42:23 AM »
Removing scratches from a canopy is not unlike removing them from any thing else.  As long as you have material that you will not sand through to remove them!  You simply keep moving up in grit and make the scratches smaller and smaller until you can polish it back to a shine.  I have started with 180 and ended with 2000, then Gorham's or a similar polish.
