  • June 27, 2025, 09:12:37 AM
Author Topic: Scratch built Brodak Strega with Saito 72 for power. Hints and tips  (Read 11558 times)
Offline Ivan Bolton
I am seriously considering  a scratch built Brodak Strega for my next project.  I want to use a Saito 72 with the UHP control line conversion.  Are there any particular modifications I could/should make to this airframe when scratch building.  (I am conscious of watching the weight)   For example does the nose need to be shortened and perhaps the tail moment lengthened  to get it to balance with this heavier motor??  I would be grateful for any building tips/advice/shared experiences  as far as this airframe and engine combination  is concerned.   Thanks
Re: Scratch built Brodak Strega with Saito 72 for power. Hints and tips
« Reply #1 on: October 28, 2012, 12:27:21 PM »
    Get the plans, and make sure you use the airfoil from the original, NOT the ARF airfoil. The LE radius should be at least 1/2"
Offline Brad Smith
« Reply #2 on: October 28, 2012, 02:14:09 PM »
Brett what needs to be done to arc wing i have one im starting on?
Brad smith AMA780054
Offline Ivan Bolton
« Reply #3 on: October 28, 2012, 02:17:24 PM »
The plans are on the way hopefully.   Surprising that the plan and the ARC/ARF rib sections are different.
« Reply #4 on: October 28, 2012, 02:27:25 PM »
     The LE is *way* too sharp. If you have an ARF/ARC, round off the LE as much as you can without going through the sheeting. The stock ARF airfoil stalls very easily even in benign conditions.
Offline Brad Smith
« Reply #5 on: October 28, 2012, 03:17:44 PM »
Should it be blunted or rouned off.
Offline Ivan Bolton
« Reply #6 on: December 02, 2012, 03:07:25 PM »
Well I have spent the last month in the workshop and the Strega is now built, finished and ready for testing.   I used 3/8" square on the leading edge so that I could round it off well as per all the comments I read about it being too sharp.  I shortend the nose by 1" for the Saito 72 and it balances nicely, so I won't need to put any weight into the weight box I built into the tailend of the fuselage!!  The Saito has a UHP C/L manifold set fitted.   It now needs some let up in our horrible weather so that I can test it.
 I have found this article helpful and intend to use its advice in running the Saito.  http://flystunt.com/ARTICLES/4stroke.htm  The tank is built as per the recommendations therein.
Thanks for the help
Offline MarcusCordeiro
« Reply #7 on: December 02, 2012, 03:15:02 PM »
Looks very nice!!
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #8 on: December 02, 2012, 06:42:51 PM »
I like it.
« Reply #9 on: December 03, 2012, 05:52:02 AM »
Looks great.  Should fly great also.
Offline Brian Massey
    • California Car Clubs
« Reply #10 on: December 03, 2012, 10:11:50 AM »
That should be a good combination. I'm interested in how you like the Saito; I"ve got two 62's waiting for airframes.
Brian
AMA 55421
Madera, CA
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #11 on: December 03, 2012, 10:43:20 AM »
Thanks for the help
Can't believe I've somehow missed this thread. That article by Brad is quite old, a couple of us have taken his start and fine tuned it into what has evolved into what works much better and is allot more consistant. If you have checked out the 4 stroke section you will see we are now even running reverse pitch props.
http://www.tulsacl.com/SaitoCarb.html
http://www.tulsacl.com/ReverseSaito.html
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #12 on: December 03, 2012, 03:11:45 PM »
That looks great Ivan. I think you'll find the Strega/Saito combination a good one.
You should have no problem at all getting consistent runs with the UHP manifold/venturi
set. I've used them for years with great results.
« Reply #13 on: December 04, 2012, 12:44:04 AM »
Ivan,
The guys over at the 4 stroke forum would sure appreciate a more in-depth review of your plane and engine setup. If you have any more photos\and or comments, we sure would like to see it. H^^
Offline Ivan Bolton
« Reply #14 on: December 04, 2012, 06:58:10 PM »
Here are a couple more pictures of the model.  The wing was built in two halves in an Adjustojig: it's a big beast!!  Fuel will be Omega 20% Coolpower patten fuel.  There is a very limited range of pattern fuel here in Ireland, i.e. just Coolpower!!  The Saito 72 has had a chequered history: it was originally in a Great Planes Venus mini pattern R/C model and it then survived a workshop fire caused by a lipo!!  I have a selection of wooden props on the way to try out.  There is an APC 13X6 on it for the pictures.  I will try it out as soon as the cold windy weather here in Ireland clears.  I use pusher props on some of my eclectics with good results so I am very interested in the comments on reversing the Saito!!
« Reply #15 on: December 04, 2012, 09:05:43 PM »
You scratched built a Big Jim Patternmaster, and used a Saito big block reclaimed from a fire. Ivan, as far as I am concerned, as to you being a modeler, you my friend, are the genuine real deal. Congratulations!! H^^
Offline Ivan Bolton
« Reply #16 on: December 05, 2012, 05:22:47 AM »
Thank you.  In our miserable climate there is lots of time for building:  winter, spring, autumn and"summer".  Since I retired I get a huge amount of satisfaction/pleasure/fulfillment from scratch  building,  only matched by the satisfaction I get when the weather finally clears enough to get some flights and F2B practice in.  The Saito was lucky enough not to be "cooked"  or water damaged in the fire like 99%  of the rest of my motors, models etc.  I'll post in the four stroke forum as I get experience (or experience problems!!)  in handling this motor.  I love 4 strokes and look forward to this application to C/L
Ivan
