General control line discussion => Open Forum => Topic started by: Sean McEntee on July 08, 2016, 02:57:59 PM
Title: SCRAMBLE!!! MODEL AVIATION IMINENT!!
Post by: Sean McEntee on July 08, 2016, 02:57:59 PM
SWO is forecasting favorable winds for test flight: consistent 10kts.  That's about as good as it's going to get here for this time of year.  I tried reinforcing the LE/fuse joint--not much meat to join to the fuselage with that battery notch cut into the LE.  Perhaps it doesn't need as much being electrics but it's as strong as it's going to get with the supplies and equipment I have here.  An interesting note: 15 minute epoxy sets up in minutes out here between the heat and the lack of humidity so one has to work fast.  If anybody comes out here after me, bring 1-hour slow cure with you!
Gonna run home, throw some batteries on the charge, and head out with the sun to try to get this thing flying.  Stay tuned.
Title: Re:
Post by: James Holford on July 08, 2016, 03:41:43 PM
Good luck!!!
Title: Re: SCRAMBLE!!! MODEL AVIATION IMINENT!!
Post by: David_Stack on July 09, 2016, 06:42:53 AM
A true enthusiast will ALWAYS find a way to pursue their passion.
Thank you for your service Sean...
r/
Post by: Sean McEntee on July 09, 2016, 07:37:39 AM
 HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~>  HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~> HB~>
Post by: Sean McEntee on July 09, 2016, 07:43:15 AM
   So I didn't know that BOTH connectors had to be plugged into the charger.  Thanks to James Mills and Crist Rigotti for quickly diagnosing my rookie mistake  ;D  I have the proper adapter already on order.
It would normally cause a fit of rage, but I was laughing about it last night...still a pleasant distraction from the "Groundhog Day" existence out here lol.
Well try again in about a week or so.
EDIT: James I'm going to let that "officer" remark slide  LL~
Post by: Rich Perry on July 09, 2016, 10:28:26 AM
Be sure to watch those batteries closely when charging, and it is best to have them in a fireproof container.  They can and will ignite!!!   A fellow club member burned his garage down a few months back.  Lost almost all of his models.  It is best to balance charge every time.
Post by: Sean McEntee on July 09, 2016, 12:16:28 PM
Sage advise Rich. I have bags for each battery and they don't leave them until it's time to fly. I also keep them in a "tactically acquired" .556 ammo can that is lined with foam to prevent shorting. Would have allot of people mad at me if I burned the barracks down!
Post by: Paul Wescott on July 15, 2016, 01:30:49 PM
How long before the adapter arrives Sean?
Paul W.
Post by: James Mills on July 15, 2016, 04:13:31 PM
Made me laugh #^
James
Post by: Target on July 16, 2016, 04:13:06 PM
You probably already know this, but if you mix your epoxy in a cup, then spread it out on a paper plate (or the last issue of Model Aviation, AKA "Drone Monthly", it will cure slower since it won't exotherm.
Of course, if you need it grouped up for application, it's not helpful having it spread out on a plate.
But if you are brushing it on an area, this works pretty well.
Your connector picture and post gave me a belly laugh, thanks for that AND your service!
V/r,
Chris
